Question about GE DBSR453EBWW Electric Dryer
Dryer is not drying clothes.
It is tumbling and I can hear the motor working. It has been taking a long time to dry the load of clothes lately. Now, after 2 cycles of drying, the clothes still aren't dry, but feel warm.
It is a GE dryer, model DBSR453EB3WW, purchased new sometime between 2006 and 2007.
  • 1 more comment
  • robinsons118 Apr 22, 2009
    Thanks for the info. It is getting hot and the back of the dryer is really hot. Could it still be the heat selector switch or a thermal-limit switch/tstat? I checked, the blower is working and I also took the venting off and make sure there was no blockage, it looked good.
  • Samuel Charles Spriggs May 11, 2010
    By really hot, do you mean it is too hot to touch as in it would burn you if you held it long enough?
    Sounds like it is only heating on low. Could be the heat selector switch or a thermal-limit switch/tstat.
    If you want to discuss further, let me know.
  • 532 Answers
Well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Posted on Apr 22, 2009
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Frigidaire Galaxy Dryer tumbles but heats to dry seldomly
What is the model number of the unit?
Nov 13, 2012 | Dryers
The heater appears to be heating when drying but it takes 2 to 3 times to get a load dry? Thank you for the help. Scott Model 68712894
if your dryer feels hot inside and the drum tumbles then you have a blocked vent. check that the venting blows to the outside. do this test. unhook the vent behind the dryer, dry a load of clothing and if it dry on the first time then you know the house vent is clogged. cleaned or if you live in an appartment have maintenance clean.
Feb 12, 2011 | Kenmore Dryers
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Hi. Our dryer will start normally and then the
HI. This will occur when the there are issues that concern the integrity of the timer motor. This mechanism is responsible for the rotation of the timer module.It is damaged at this time, and it must be replaced asap.
A damaged timer motor will affect the nature of the drying cycle. It is the main initiator of all functions during the selected cycle.
Oct 29, 2009 | Dryers
CLOTHES DRYER (ELECTRIC) HAS HEAT AND TUMBLES BUT CLOTHES ARE NOT GETTING DRY.
DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER. RUN ONE LOAD OF LAUNDRY. IF THE LOAD DRIES O.K., THE EXHAUST DUCT IS RESTRICTED. CLEAN OUT THE DUCT WORK. IF IT IS FLEXIBLE MATERIAL, REPLACE WITH RIGID METAL DUCT WORK.
Apr 22, 2008 | Dryers
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
GE DBSR453EBWW Electric Dryer Logo
520 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
