Question about Psi Blue Max 2200 High Pressure Gas Power Washer
The pressure decreases when trying to wash
It idles rough also looses pressure when using it. Changed spark plug.
Still the same
  • 92 Answers
Dear rjrdiaz1013,
First you must find out where the real problem is. So first you must see that the engine works smoothly.(checking spark plug, spark plug gap, fuel mixture..etc..etc..). You have to do this by having no load at the pump. So remove water inlet hose and gun. If you manage to get the engine running smoothly,...then for sure you must service the pump. The pressure usually decreases from a faulty "Spill Valve". When the gun is closed the spill valve compresses and lets water circulate. When the gun is opened, the spill valve extends and closes an opening at its end. If this opening is not closing correctly, then the water keeps circulating and hence no pressure. My advice change the 'Spill Valve" by a new one. If the pressure is not 100%...then the next step change the suction valves. To change the suction valves, you must also change the high pressure and low pressure seals. Also better to change oil and oil seals. BUT the pistons must be examined. If the pistons have damage and cracks, these must be renewed, because they will ruin again the seals. In problems like these, I always fix the problem by changing the Spill Valve and the suction valves if need be.
When all necessary service is done, always try to start the machine with no load first. Also inportant that all seals and spill valve must be lubricated with the correct silicon grease.
Regards,
Fulltech.
Posted on Apr 22, 2009
2005 buick lacrosse 3.8 changed spark plugs coils N wires still shakes and sputters rough idle
The basics for vehicle with rough idle, check for a leak of some kind, fuel--egr--vacuum leak. How long since an over-all tune-up? You can check the idle air system? Any applicable trouble codes? To check codes yourself, at the least, you need an obd2 code reader.
If spark issue, sometimes you can use a digital multimeter to do some testing, low tech, non--invasive. With digital multimeter on low voltage setting, engine idling, touch spark plug wires, one at a time, do not penetrate insulation, don't take spark plug wire loose, it's an inductive reading. The point is if you get a reading bouncing off zero, that is where you start testing. I know you changed the coil/s, but sometimes, you need to check ignition module. I'm not saying that module is faulty, I don't know.
Feb 25, 2017 | Buick Cars & Trucks
I'm having rough idle and smoke all of a sudden with my golf mk4 The oil warning lights up in dash. Oil level ok. Spark plugs not burning well. Replace spark plugs, changed oil filter, changed
Smoke is not a good sign. Running rough is not a good sign. Oil light not a good sign. You could have a combination of bad things, most likely expensive. Suggest professional help. Smoke can be bad rings or holed piston. Low oil pressure can be bad bearing or oil pump.
Nov 04, 2014 | Volkswagen Golf Cars & Trucks
Decreased engine, now it shudders & idles rough
The water has gotten past the plug boot seal. Pull the plug tire off the plugs and use some compressed air to blow out and dry the plugs. Some times the water can really get deep so don't pull out the spark plugs.
Mar 23, 2014 | Suzuki Vitara Cars & Trucks
Changed oil in bmw e36 now spark plug socket and spark plug are showing engine oil (old) Shop gave me wrong oil filter so have not started car yet as I do not have the right filter Also I changed air
IF there is a sleeve around the spark plugs then when replacing the plugs replace the seal under that sleave as well or rocker cover oil will leak out past the plug base.. If you want the correct oil filter you may have to buy genuine . Run fault codes to find the reason for rough idle . It may be a vacuum hose is off or cracked or loose.
Feb 16, 2014 | BMW 318 Cars & Trucks
2007 chrysler town & country has a rough idle but drives smooth what could it be
If it idles rough it runs rough,you just don't
notice it
You can start anywhere you want
If you haven't changed spark plugs in 3 years do that
Replace any front or upstream O2 Sensors over 100,000 miles
Check fuel pressure,tps sensor voltages,check for loose air
filter cover,vacuum leaks,loose O2 sensor,just go thru the
entire engine,it obviously needs work & I will bet it hasn't seen
much & you don't know what is done when you ask & pay
for work.
May sound harsh but many shops aren't there to resolve problems,
they throw on as many parts as the people on this site do at home,
from the questions is see here,dealers guess as well and don't road
test,kind of sad really
Nov 13, 2012 | 2005 Chrysler Town & Country
VERY ROUGH IDLE NO EXCELERATION
Try a few if these ideas...
Priority Action Part Type Cause
1 Inspect Spark Plug Fouled, Damaged, or Broken Spark Plug(s).
2 Inspect Hose (PCV) Clogged or Collapsed PCV Hoses.
3 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s).
4 Inspect Distributor Worn, Damaged or Faulty Distributor.
5 Inspect Catalytic Converter Clogged or Faulty Catalytic Converter.
6 Inspect Fuel Pump Low Fuel Pressure.
7 Inspect TimingSet Slipped TimingChain or Worn TimingGear(s).
8 Inspect Knock Sensor Improperly Connected or Faulty Knock Sensor.
9 Inspect M.A.P. (Manifold Absolute Pressure) Sensor Faulty M.A.P. Sensor.
10 Inspect Throttle Position Sensor Faulty or Incorrectly Connected Throttle Position Sensor.
11 Inspect Mass Air Flow (MAF) Sensor Damaged, Loose, or Faulty Mass Air Flow Sensor or Circuit.
12 Inspect Air Cleaner Temperature Sensor Damaged or Faulty Air Cleaner Tempature Sensor.
13 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator.
14 Inspect Piston Ring Set Worn or Broken Piston Rings.
15 Inspect Timing Specification Incorrect Ignition Timing.
16 Inspect Fuel System Pressure Incorrect Fuel Pressure Being Delivered to Carburetor or Fuel Injection System.
17 Inspect Fuel Filter Clogged or Dirty Fuel Filter.
18 Inspect PCV Valve Plugged or Damaged PCV Valve.
19 Inspect Valve Burned, Worn, or Sticking Exhaust Valves.
20 check idle stop solenoid - if faulty, could cause rough idling
21 inspect distributor cap/rotor - if burnt, could cause loss of acceleration
Apr 18, 2011 | Chevrolet Cavalier Cars & Trucks
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
198 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
