Car ac blowing hot air
2001 Saturn SC1 A/C blowing hot air. How much freon did i need to replace or add to get cold air
  • Ken Bledsoe May 11, 2010
    It is always on the top of the engine somewhere. Most of the time 28 ounces.
  • 128 Answers
Pls the qty of freon is depending of the size but you can not add freon any time since no leak so chek may be
- thermostat
-hot water coil is on
- selector on heating
- compressor is defective or the clutch or coil
- low pressure swith open
-high pressure switch isopen
Posted on Apr 25, 2009
My 2002 Saturn sc1 is blowing cold air and no heat.?
Hello. If change the tempature setting from hot to cold dose it click. If so you need to replace the blender door motor. If not they you need a heater core and if it's the heater core you should smell anti-freeze inside the car.
Feb 23, 2015 | Saturn Cars & Trucks
My ac is not blowing cold in 2001 saturn sl1. I had the cooling fan replaced and it blew cold for 1 day. Then I bought a recharge kit and the pressure was to high for me to add freon. I took it to the shop...
If you can turn the compresser with your hand freely ? then you can just replace the clutch...if not, the whole compressor needs to be replaced..
Jul 06, 2011 | 1998 Saturn SL
Why my ac in my cadillac deville 1996 blows hot air?
If your low on freon then the A/C wont come on? for a 1996 you will need to get it serviced if you havent its normal to loose 10% freon a year,
May 06, 2011 | 1996 Cadillac DeVille
I HAVE A 1995 SATURN CAR 1.9L AND THE QUESTION IS. THE AC BLOWS BUT ITS LIKE THE HEATERS ON, AND THE COMPRESSER ENGAGES BUT DOESNT BLOW COLD AIR, I CAN SWITCH THE POSITION OF WHERE I WANT THE AIR TO COME...
Most likely the freon has leaked from the system. Replacing it is a fairly simple process, but finding and repairing the leak is expensive (labor wise). Plus, in the States, federal law prohibits non-licensed personnel from working with freon and it's descendants. Find a good AC service shop and get an estimate--you may not need that AC air as much as you thought! Good luck!
Apr 14, 2010 | 1993 Saturn SL1
Air conditioner gets hot on passenger side while drivers side is
either your R134a is leaked out ore you need add and also add a dye see if leaks.
Add to the low side the car while running with gage with ac cranked on high follow metter dont over fill it loc the ac up. Easy 20 minute job wallmart sells the gage and R134s and so do auto zones
Jul 28, 2009 | 2001 Lincoln LS
Saturn ac wont blow cold air
check cooling fan operation while ac on.If fan is working proper,will probably have stuck exspantion valve.
Jun 18, 2009 | 2003 Saturn L-Series
My ac blows hard, added freon, clutch not turning could it be fus
If the blower is working,it indicates your car blower system is ok.If the freon system is contain the correct amount and still clutch is not turning when the A/C switch is in the on position check the supply for the compressure.If there is supply that means the problem with the A/C compressur clutch coil and apply the repair procediure or replace A/C cpmpressure.If there is no supply Check the fuses,wiring system and A/C system pressure switch.
Jun 06, 2009 | 2000 Saturn SC
2001 Saturn L200 heat only blows high. A/c out.
Sounds like a possible broken/ripped/disconnected air line (hose) to the compartment.
Mar 18, 2009 | 2001 Saturn L-Series
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
