Question about HP DeskJet 932c InkJet Printer
My HP DeskJet 932c InkJet Printer wont print photo paper.. ANY! it starts but then suddenly stops, then deletes the printing job all by its self.. it will print on regular paper. i also set up the print that im using the certain type of paper... plz help :)
  • 75 Answers
Try adding some sewing machine oil to the slide bar
Posted on May 10, 2010
I'm trying to print an article from the computer and blank pages keep running through the printer non-stop.
Try canceling the print job, unplug the printer and plug it back in. Copy the article to a Word Doc. and print it from there.
Dec 07, 2010 | HP DeskJet 932c InkJet Printer
All of a sudden my hp 932c printer started printing funny in color. I was printing pictures and the prints came out like a heat resolution type picture. I then got new ink cartridges, it did not fix the...
quite often inkjet heads will dry up and clog. try a clean heads sequence in the printer properties panel. do this until it prints the clean nozzle page properly. If the ink cartridges have the print head attached to them (some dont) you can dab them on a paper towel with windex or vinegar until they show a nice clean line when dabbed. if you cant get the print heads out , then you just need to continue running the clean nozzel application until it prints the test nozzel job properly. This is the reason I will not buy any more inkjet printers. only Toner based machines. cheers.
Aug 25, 2010 | HP DeskJet 932c InkJet Printer
The Hp deskjet 932c went to the far left position and the light is flashing. That is supposed to mean its out of color ink but its not. I uninstalled the software and reinstalled. It will start to print a...
Follow each of these steps until the problem is resolved:
  • Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  • Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present
  • Remove and then reinsert the print cartridge(s) into the printer.
  • Print the document.
  • Try printing again. If the problem continues, replace the print cartridges.
Aug 04, 2010 | HP DeskJet 932c InkJet Printer
Hello, My HP 932C has suddenly started printing photos in pink. I have tried cleaning all the cartrdge contacts, reinstalling the software, a new cartridge. No change. Any ideas?
Your cartridge may need to be replaced. If your tri-colour cartridge has run out of yellow and cyan and only has red left this could be the cause.
Jun 08, 2010 | HP DeskJet 932c InkJet Printer
How do I cancel a print job?
just turn the printer off...and delete the commands from the error and job folder...you have to insist ...and try to open it from control panel or Hp in all programs .if it doesn't work from tray system ...this is the way to annul the commands...if it does not want to ..restart and try it again until it get rid of it ...restarting will make it not see that is used by another device ..
Nov 11, 2009 | HP DeskJet 895cse InkJet Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
THE PRINTER WILL PRINT ON NORMAL PAPER BUT NOT ON kODAK PREMIUM P
Ok,, thanks again for the additional info. I had the same problem at one point with my HP photo printer, it seems the electronic eye that watches for the edge of the paper somehow can't see/focus on some of the high gloss papers.
How I tested it was simple. I roughed up(wrecking) one sheet and ran it through, it saw the page and printed. after that I tested with semi-gloss and it seems to work better.
Give that a try and let me know if that works.
Chris
May 27, 2009 | HP DeskJet 932c InkJet Printer
My printer jammed in the middle of a page and after I turned it off, pulled out the paper and turned it back mon its printing 1 line of jibberish and pushing out the rest of the page blank, page after...
Your printer queue still contains fragments of your print job
  1. Remove print job at your computer if listed
  2. Turn off printer
  3. Disconnect printer power supply
  4. Reconnect printer power supply
  5. Turn on printer
Your queue should be empty now.
May 05, 2009 | HP DeskJet 932c InkJet Printer
Printer won't stop printing garbage
Try and re-install your printer drivers...first remove the drivers and delete the printer...then re-install.
Dec 03, 2008 | HP DeskJet 812c InkJet Printer
HP DeskJet 932c InkJet Printer Logo
147 people viewed this question
Seeker5211
Seeker5211
