Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Compressor replaced and now just dies- have to unplug and plug back in, but still not reaching temp=-
We purchased in 2005- compressor just died- had A&E services finest come out- it was awful- took 3 weeks to get part and repair- three days later it is just stopping to work- lights on- but the digital read out in fridge just reads dashes no numbers- we have it set at 4 when working- The food in freezer is all soft. The tech was so rude and mouthy and actually was fighting on the phone with customer service about charging us $75.00 visit charge- the customer svc waived because they kept screwing up- sending dishwasher guy and then all the time they took- they were trying to give service- but the tech was so spun up he yelled the whole time and I feel he was not focused on his job- felt like we were sitting ducks after he left- and now we are- we can unplug fridge and plug back in, but still not getting temp up- HELP! :o)
  • 2 more comments
  • dccaswell Apr 21, 2009
    They replaced compressor 4 days ago, the fan is running in compressor and freezer- the compressor cover is warm and there is no ice or condensation at all on rear freezer wall. When we woke this morning and everything was thawed in freezer and warm in fridge we unplugged it and then plugged it back in and it all started working again. Freezer was not up to par all day- then around 5 it started getting cold again and working. thank you! :o)
  • dccaswell Apr 22, 2009
    Thank you- cleaned? He had a tank, the compressor that was delivered to our house and I believe a blow torch maybe to terminate connections or something along with a bag full of tools. It smelled pretty bad - but cleaning with a vacuum never happened - so your solution sounds fitting- I will make a service call for them to come back and fix- thank you! :o)
    Thank you- A&E Tech called back this morning and said if all is working fine today then they can not come back until it happens again and they will note on file for next time and for us not to unplug and plug back in to get it started again. I asked about the cleaning and the tech said he was a different one from who installed compressor a few days ago and that to call the 800# next time it happens not their office (I had number on my phone from last week when his cell did not work in my hosue). I asked if he could check with that tech and he said doesn't matter since it is working now- so I said well can you still come out and check to make sure it was cleaned and he said he would charge me a visit charge and labor to do so since there is nothing wrong in their eyes. So we wait I guess - unless I can do it myself? I also called 800 service number to note it on my file.
  • steve
    steve May 11, 2010
    I now know about your problem with the service tech.
    Now tell me about the problem with the fridge.
    Is the compressor fan running?
    Is the compressor Running?
    Is the compressor hot to the touch?
    Is the freezer fan running?
    Is there a ice buildup on the freezer rear wall?
  • Maytag Master
  • 3,361 Answers
I believe they did not vacuum the system correctly and allowed a restiction in the line. Otherwise it would have cooled correctly from the beginning.
Your turning the system off and back on allowed the restriction to move further down. It will probably lodge in the filter dryer.
The filter dryer should be changed again. The reason being the system was not cleaned properly when they replaced the compressor.
Posted on Apr 21, 2009
  • steve
    steve Apr 22, 2009
    When I say vacuum, that would be a vacuum PUMP. It would have been attached to the service valves with gauge hoses and run at least 30 minutes before charging with refrigerant.
    The purpose is to remove air and moisture from the system(non-condensable elements).
I have a 97 chevy and my truck is ideling rough so with truck running i unplug the maf sensor and truck died instantly plugged back in fired right up and also with truck running i unplugged iac agian truck...
The MAF Sensor measures air flow & temp,unplug it shuts off
The IAC-idle air control-unplug shuts off
It means you need to pay a professional to find a problem
Dec 03, 2014 | Cars & Trucks
Have power but compressor no work
Tried unplug,replug it back in half or an hour later.Most of the time the the compressor will reset and kick in than it work again.This is a temp solution only,because most of the compressors in frig have this intermittent problems will died again because of over heat the design 24/7 plugin doesn't help especially continue of power to it.Replaced the frig if it more than ten years or replaced the compressor if less.
Sep 04, 2013 | KitchenAid KSCS25IN Side by Side...
When my 1991 Isuzu trooper reaches normal oper. Temp. It dies and I have to wait till it cools down and it will start right back up and go some more till it reaches temp. Again. Runs great cold but when at...
model with coil fitted check this as when they over heat they stop sparking. also the spark plugs and leads, up graded model with electronic timing check the dis pack and then the spark plugs and the leads, leads can check with meter, if hard or stiff leads replace them as this can mean they will crack with engine movement. check spark plug gap to your recommended speck for your engine code. coil should be replaced every 5 years or depending on your driving times these can very depending on coil fitted. dispak type if it has any cracks in the casing replace as water could of damage the internal coil.
Dec 21, 2017 | Cars & Trucks
Honda Odys 2005 DVD Player doesn't work
Unplug the battery for one hour and plug back it, it should work.
Mar 26, 2010 | 2005 Honda Odyssey
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
Freeezer with no compressor activity
If all fans are running, but not compressor You could try to install 3 N 1 start kit, thats might help 50/50. If it will start compressor - be ready for compressor to go out soon. might work for a year.
Dec 13, 2009 | Kenmore Freezers
Dies after reaches operating temp
themastat in radiator or temp sensor on top of motor...
Dec 30, 2008 | 1987 Chrysler Fifth Avenue
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
163 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
