Question about Epson Stylus Photo 1280 InkJet Printer
Question on brothers multifunction
Question for brothers mfc3360c in coping the original comes half way thru and sticks- the paper for the copy slides behind thetray and is blank;
I only want to use this and print in black and white...can i override the so i can just use it without the color inks
Posted on Dec 27, 2007
SOURCE:
After feeding toner, my Ricoh mp 5001giving bad result in coping. How to solve this problem?
remove the toner bottle and make around 50 copies but make the copies in A4 LEF but with open ADF and put a white paper on half of the A4 LEF area for to be the copes half white half black. This must be done for the extra toner that is inside the developer unit to be removed. It must be half black-half white for the machine can print the copies, otherwise it will constantly jams. pit the white paper in the right half section of A4 LEF area and make around 50 copies. But do this without toner bottle inside the machine. After the 50 copies end,print a counter and see does it got better. If is ok then return back the toner bottle and the machine will continue to work. If still the copy is bad then make more copies without toner bottle until the image is clear.
Apr 11, 2018 | Ricoh Office Equipment & Supplies
At random times, when a user prints, a document, pdf, picture ect.., it's slanted. It also happens when a user scans to themselves. What can cause this to happen?
There mite be something in the path of the paper which the paper hits and so it is slanted have you tried scanning on the big glass instead of thru the document feeder does it happen then? Now the printing is something else are you talking about copying or printing. If print I would check the paper draws ensure the guide are snug up against the paper. Do you internal prints slant such as the meter count print out or the fax info reports. or the demo page? If the problem is coping then place the original on the big glass and see if the slant There are small mylar guides though out the document feeder if some one pulled the original document out in the wrong direction they mite have flipped on of them causing a corner of the paper to hit one slanting the original ALWAYS pull the original out in the same direction as the flow of the document. Try sticking a business card down thru the way the paper flows you mite be able to reset the offending mylar.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 22, 2014 | Konica Minolta bizhub C250 All-In-One...
My samsung clx 3170 keeps jamming up after every copy. You can see where the paper is trying to roll thru. because there is a slight indentation in the paper about a third of the way on each piece of...
Use this link and you will have all the information on your printer you should ever need
http://www.samsung.com/au/consumer/print-solutions/print-multifunctions-copiers/colour-multifunction/CLX-3170FN/XSA/index.idx?pagetype=prd_detail&tab=support
good luck
Nov 29, 2010 | Samsung CLX-3170FN All-In-One Laser...
I have a Brother MFC-8660DN. When I receive a fax
That type of problem comes from either the drum or the fuser, the best way to check is to unplug the machine while it's printing and see of the shadow is on the paper before the fuser, if it is then you need a new drum, if not the fuser is the culprit.
Oct 28, 2009 | Brother MFC-8660DN 5-in-1 Laser...
Our HP laserjet M1522n has a vertical line going through the paper when using the top feed. the line doesn't appear on copies made thru the computer or on the flatbed, only thru the self feed. any one??...
If you open your "self feed" cover, you should be able to see the scan glass that originals pass over to copy. Clean that glass thoroughly. There is some dirt or whiteout (liquid paper) on it which causes the shadow or line on copies. Let me know.
Oct 15, 2009 | HP LaserJet M1522n MultiFunction Printer
Paper sticks half way when I try to FAx
Probably the left hinge is broken not letting the adf cover go all the way down and causing jams. A new hinge is #LP2403001, around $15 to$18.00
Aug 20, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC3360C paper drawer will not open
remove the paper tray
remove the jam clear cover in the back.
Lift the Pull In Roller
Holder Assembly with a
credit card.
be careful not to lift too much
While lifting the Holder
Assembly, pull the tray
free from the machine
lubricate the right side with a little bit grease where the vshape is located on the tray
Apr 16, 2009 | Brother Multi-Function Center MFC-3360c...
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
FAXING SAYS CANT SCAN TROUBLESHOOT ROUTING , DONT HAVE A BOOK
usually something on scan glass..ord lamp is bad..try coping blank paper..if line shows up...check glass clean and try again..
Dec 26, 2008 | Brother DCP 7010 Multifunction Laser...
Brother multifunction inkjet DCP770CW. How can you adjust the copy function to cope with pages of pencilled notes that come out too feint. Mike Cornwell
no way. the paper feeder of machine recognices the paper edges. there is no way to compute the exactly positon for different papers.
May 01, 2008 | Office Equipment & Supplies
Epson Stylus Photo 1280 InkJet Printer Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
