Question about EliteGroup ECS 915-A Intel 915GV Chipset 800MHz FSB DDR2 533 Socket 775 ATX Motherboard with Integrated Graphic... (MB77ECS0915A)
Problem with sata HDD probably?
The motherboard is ecs 915G-A. HDD 160 GB SATA, ATA DVD combo,RAM 2x256 PC3200, VGA onboard. OS: Windows 2003 Server. After bios reset I can't install any OS on my computer. For example: Windows XP installer starts and try to check hardware configuration then black screen appears, and nothing more. Only silence. Please, help me to solve the problem.
Check the bios settings first. if you can see your sata hdd and dvd rom drive then you can install it with no problem. or else try to replace the cables of the hdd if the hdd is not showing up in the bios.
also check that the hdd is set to master drive and dvd also set to master as they are on different connections.
Posted on Apr 22, 2009
Dear i am using ms-7142 v-1 motherboard. now i,m using ide 80 gb hdd.now i want to connect 160 gb sata hdd.its not showing bios also.hdd is working fine.i reinstalled os.and installed sata raid driver
first thing I would try is seeing if the sata drive is recognised on another motherboard if at all possible ,in order to eliminate the motherboard as the issue.If it is recognised on a different motherboard it is more than likeley a bad cable or a bad board .
Sep 23, 2014 | Computers & Internet
Can't setup OS in SATA HDD in Intel d945gccr
Hi.
XP will not install until you go into the BIOS and find the menu page (probably by moving across the top level of tabs) where the SATA hard drives are configured. On that page you will see the ports and at least one, maybe all, will be Enabled. Close to that will be the port mode, usually setable individually for each port. Choices may include IDE (or PATA) Emulation, SATA, AHCI. Set your port to IDE emulation. Now look at the bottom for the key to Save and Exit - often the F10 key, press that key and select OK, the computer will restart and you should now be able to install Windows XP without any problems.
To get into the BIOS you have to press the Del or Esc key when you first turn the computer on.
Regards.
Feb 04, 2013 | Intel D945GCCR Motherboard
We are using IBM X226 server with 4 GB RAM & 146 GB SCSI HDD. We are using it for ERP application . It is very slow . When HP proliant ML 110 server with 2 GB & 160 GB SATA is used in its place it...
strange. with 4gb of ram, it should be fast. try to install better version of windows like win 7. it could help you. just don't install vwindows vista cause is slow as hell. let me know if it worked
Jun 28, 2010 | IBM xSeries 226 Server
Problem to install windowxp
Win XP can't install in an SATA disk, it lacks the correct drivers. You can install it if you can load the correct/personalized driver during install when notified.
Otherwise go into the MB's BIOS and set the SATA chip to work as an ATA one. You can configure it later if you want a very small to non detectable  HD speed increase.
Oct 04, 2009 | Intel D915GAG Socket 775 Motherboard -...
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
Did you get an error message during install of the (system with the SATA 160GB drive)? Make sure the 160GB drive is shown in the bios. Than go to the title, Boot in the bios & make sure the SATA 160GB is listed in the boot order. (Preferred 3rd. boot device)
Please go to the SATA drive's manufactures site & download either their bootable floppy or CD setup software. (It’s free)! Use their software to setup the FAT & cluster size on the drive. You can even set other features that neither the bios or windows can do. Format the 160GB drive with the software as well. The manufacture's software does a better job than windows. If the 160GB drive is a SATA 2.0 leave the jumper on the drive alone. The Desktop Board supports four Serial ATA channels (3.0 GB/s) via ICH7, connecting one device per channel.
Again, please run the manufactures setup software for your SATA 160GB drive. (Disconnect any other drives that may be in the system until windows is installed).
Intel's web site here: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Good luck ameyaniks!
If I missed something, just let me know.
Mike
Sep 11, 2008 | Intel DG31PR Motherboard
Motherboard 755-a2
I go Why can't I install Windows XP on my S-ATA HDD by SiS964? A: You have to copy the driver paired with the motherboard package into a floppy disc before you installing WinXP or Windows 2000 on your system, and follow the notice showed on the screen to insert the floopy disc. The system will grab the needed driver from the disc to finish the installation of S-ATA HDD automatically.
Because SiS964 was announced before than Windows XP and WinXP therefore it can't recognize it. If you want to install a whole new WinXP (or Windows 2000) on S-ATA HDD by SiS964, you need to copy the necessary driver from the directory named floopy image on your driver CD to one floopy disc. When you begin to install OS, follows the instruction to put your disc into floopy drive. After this, you will keep on installing your WinXP smoothly. If you use P-ATA HDD, you don't need to do like this.
t this off the sis.com web site what does it all mean.
Sep 03, 2008 | EliteGroup ECS 755-A2 Motherboard
Well I'm one of you guys so you can bet I was confused, this is a computer problem installing XP SP3 on my PC.
clean install ............. floppy... fdisk deleting all partitions first.... and then making a partition of the whole disk.. then formatting.... then do the install and of course ntfs.... and see how that goes
Robert
Sep 01, 2008 | Intel Motherboard
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
100 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
