Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
With the chain off the device, I start the engine
With the chain and bar off the device, I start the engine and the gear that turns the chain doesn't move. Used the saw twice for an hour or so, then it froze.
I put bar oil in and the correct fuel mix.
Is the Chain brake engaged? It's the plastic "guard " in front of your left hand.
Posted on Apr 22, 2009
Pull the hand guard back towards the handle to release chain brake
Posted on Jan 29, 2012
My 235 starts and idles fine. when you put it under a load the chain quits moving and the engine starts to bog down. pull it out of the wood and it revs. back up and chain starts to turn again. is it the...
The chain is driven by a gear.remove the cover of the chain,while the saw is idle,the chain is probably slipping off of the drive gear causing the chain to "lockdown",if this is your problem,that gear will have to be replaced.Any small engine repair shop in your neighborhood can perform this task for you.
Feb 12, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Have Ryobi 40cc 18", have
Release the chain brake and remove the bar and chain. Clean the side of the engine where the bar fits to, then start the engine and see if oil oozes out of the side port on the engine. If it does, then clean the small oil passages in the drive end of the bar that run out from the large holes to the chain groove on each edge. If the oil does not ooze out of the port, then the oil pump, oil line, or oil filter in the tank may need service. Many oil pumps utilize a plastic gear that takes drive from the crankshaft behind the clutch and are prone to stripping the teeth of the gear. Hope some of this helps!
Dec 15, 2010 | Ryobi Garden
The oiler quit on my husky 460, I replaced the plastic gear on the crank shaft, but it still is not oiling. What is the next step to get oil flowing again? Thanks ! R.J. Rose
Was the plastic gear damaged? The pump itself may be in trouble. Did you check for a plugged filter in the tank? Have you started the engine with bar and chain off? It should ooze out oil from the side port where the bar fits up to. If so, the small oil passages that run from the large holes out to the chain groove on each edge of the bar may need to be cleaned. This saw should have an oil volume adjustment screw on the bottom near where the chain returns to the engine. Turn it CCW to increase flow. Test the volume adjustment by running the assembled saw tip near some cardboard--it should throw off a thin line of oil. Hope this helps!
Nov 07, 2010 | Garden
How do you put a chain saw chain back on and how do you determine the proper tension?
You obviously have taken the chain and bar off the saw. Start by meticulaously cleaning the oil port/s. At the front of the bar on the engine side, you should find a screw that moves the blade back and forth. Turn this screw counter-clockwise to allow placing chain loop on the bar and drive gear. Make sure that the sharp portion of the tooth of the chain is facing toward the engine of the saw, then the cogs will fit correctly. At the back end of the screw that you turned, is a nib that fits into the blade of the saw. Once you start assembling it,you can tighten the screw. Tighten the two bolts holding the blade and chain just enough so that you can still adjust the screw. Now, tighten that screw to a point where the chain can still be moved freely, but does not have a droop on the under side of the blade. Tighten,run the saw a bit, readjust if necassary and you are ready to go.
Oct 16, 2010 | Garden
Bar oil is not flowing
Remove the bar and chain. Start the engine and watch for oil oozing out of the side port on the engine where the bar fits to. If ok, clean the area, then clean the two small oil passages that run from the large holes in the drive end of the bar out to the chain groove on each side of the bar. Clean the chain groove too. If no oil came from the engine port, then repair of the oil pump, drive gear, or associated components is necessary. These parts are behind the clutch assembly. Hope some of this helps!
Sep 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
How do I reattach chain after it slipped off
Normal 0 This will be the basic instruction for most common saws. Check that the chain brake is in disengaged position by moving the front hand guard towards the front handle if the saw is equipped with a chain brake on the handle. Loosen the bar nuts on the clutch cover. Loosen tension screw or other adjuster (thumbscrew) to allow the bar to be moved toward the engine. Some saws have this tension adjustment built into the bar. This will provide enough slack in the chain to able to reinstall it. It may be necessary to remove the side cover to gain access to the clutch/gear assembly on the side of the engine if the chain also jumped the gear here. Remove the cover, inspect for any debris or other obstructions in this area. If none, replace the chain back over the drive gear and in the bar groove all the way around the bar. It may be necessary to turn the bar adjuster screw more to provide enough slack in the chain to do this. Once the chain is in place reinstall the cover and bar lock nuts. Snug up the nuts but do not tighten these. Turn the bar/chain adjuster screw to tighten the chain on the bar (take up slack). I usually tighten to a point where there is no slack between the chain and the bottom of the bar and I can still turn the chain easily around the bar by hand. With experience you will get the feel for this chain tension. Once the chain is properly tensioned, tighten the bar lock bolts/ nuts on the side cover. I hope this helps you out.
Jun 25, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Oil leak when running.
Remove the bar and chain from the engine. Clean the entire area where the bar fits to the case. Start the engine--oil should ooze out of the side port only. If ok, clean the bar drive-end small oil-channels that bring oil to the chain groove on each side of the bar. Also, clean the entire chain groove. Refit the bar, chain, and cover leaving the fasteners finger tight. Turn the chain adjuster CW until the chain comes up to the bar, but not so tight that the chain can't be turned by hand. Tighten the cover fasteners and recheck the chain tension. Start the engine and run the bar tip at speed near some cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Jun 02, 2010 | Homelite ZR10926 16 Chain Saw
Chain will not move on chainsaw
Some Poulan Pros have an adjuster screw on the front of the engine case right beside the bar, some have a tool less adjuster on the clutch cover, and some have a slot in the bar for adjusting the chain tension.
May 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Gear slippage -drive gear to chain bar grates -chain doesn`t move.
Driver won't slip, your chain brake is probably on, pull break handle backwards to dis-engage the break. Is there chain oil in the oiler ? If saw has been run long enough without chain oil this would cause this to happen as well
Aug 14, 2009 | Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
152 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
