Tp link wireless router Ethernet not working
I USe a Tp-link -wr340G Wireless Router ... everything works fine on the wireless link .. but i want to connect one pc with the Ethernet cable .. it has a 4 slots through which i can do it .. i use a straight cable to connect the pc with the router .. but windows xp does not automatically get ips .. once it gets connected the two Lights in the task-bar have an exclamation mark sign ..
  • Pakistani1 Apr 23, 2009
    its on auto detect ..
    if i manually put ips there .. the exclamation mark goes away but i can't browse the internet ...
  • 32,281 Answers
Make sure the TCP/IP settings on the PC's LAN gets an IP address automatically, don't use a fixed IP address.
Posted on Apr 22, 2009
  • Chris Hingee
    Chris Hingee Apr 24, 2009
    Leave the IP on Auto detect.
    Right click on the wireless connection and click on Repair (this connection).
My wireless connection to my Sharp smart tv works - but the wired connection does not. Should the two IP addresses be the same or different for wired and wireless?
For the same hardware on your system the IP address needs to be the same, no matter how its connecting to the router. Also check your available IP addres range on the router. The IP address must be within the routers IP address range or it will not see it.
Aug 10, 2014 | Sharp Aquos Televison & Video
How to configure TP-link TL-wr340g on tata broadband
If you don't have any internet access, you can reset the router by unplugging it from power and then plug it back in. Do the same for your ADSL or cable ISP modem which you have connected on your TP-Link router.
RESET FIRST YOUR ADSL MODEM and then your router.
Other solution might be to do ipconfig /release and ipconfig /renew on your command line window from your computer.
You can find your wifi router's user manual (PDF) on this link:
http://www.tp-link.com/resources/software/200943083466.pdf
Please mark as solution if this helped you at all.
Thanks.
Jan 29, 2012 | TP-LINK Computers & Internet
How to connect TP Link G Wireless TL-WR340G Router? My neighbor wants to connect an internet with us and I don't know how to install a router.
I have found you a manual to help you with the setup.
Basically, you login to the router via a browser, put in password and network information, then save the configuration. http://office.manualsonline.com/manuals/mfg/dlink_systems/di514_1.html
Mar 05, 2010 | D-Link DI 514 Wireless Router (DI-514)
Tip link wireless router WR340G will not conect
how i can change the pasward of this router(TL-WR740N)? and i has forget my pasword and user name.
Feb 01, 2010 | NetGear RP614 Router
Cannot connct xbox 360 wireless adaptor
Your XBOX 360 adapter should automatically be assigned an address by the router's DHCP server. I think you may be having a problem with your wireless configuration. Check the wireless settings on your router to confirm that it is indeed setup for WEP. If it is setup for WEP on bothe the router and the XBOX and the key is typed in correctly on the XBOX it should work. If it still doesn't however, disable the wireless security on your router, then restart your XBOX and see if it will connect without WEP. Many devices will have problems over WEP and not connect at all. If it connects fine with no security enabled then we will know that was the problem and I would sugest changing the security to WPA.
Jan 05, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless ethernet from a wired router?
You can buy a wireless access point to plug into your router. The thing is, you can buy a new router with wireless built in for about the same price. It's up to you to shop and compare.
In either case, you will need to configure the wireless, and create a WEP key to share with the wireless in the computer(s). The new wireless will come with instructions.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 28, 2008 | Dynex DX-E401 Router
TP-LINK TL-WR340G, No internet connection
Look for the MAC address clone feature on the router. If the router does not ahve the auto clone MAC feature, you'll need to manually input the MAC address of your computer.
To get the MAC address or Physical address of the computer do this
Click start>run>type in "cmd" and press okay (without the " ").
On the Command prompt type in ipconfig/all and then press enter, look for physical address.
Then input that on the MAC clone feature of the computer to your router and then power cycle everything (turn everything off and then turn on modem first-then router-then computer).
Sep 12, 2008 | Trendware TEW-630APB (TEW630APB)
TP-LINK 54M Wireless Router
pls ckeck your connectivity status
use this command to test for connectivity from your isp 'ping <ip address>
Apr 23, 2008 | Computers & Internet
Computers & Internet Logo
395 people viewed this question
David Payne
David Payne
