I have a Vizio VU 42L . Problem with video when I switch it on
When I switch it on sometimes the audio comes on but not the video. When I turn the set off and on again it is OK. This happens when I use the remote and also with the switch on the set.Vizio ordereed a replacement tv but the same thing happens.I have the satellite signal fed through a DVD recorder and then to the TV. What might be the cause and how can I fix it?
  • 87 Answers
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Posted on Oct 23, 2007
SOURCE: vizio vx37l green/red/blue sparkles
Call Vizio tech support and start a case. i am having the same issues with mine and i have sent it back. they will be replacing it this time.
Posted on Apr 09, 2008
SOURCE: lag in video to audio on Westinghouse LCD 26' TV
Register your tv (whether under a year of date of purchase or not) and get a firmware update. It is simple and works like a charms, sync of voice and images is great afterward.
Make sure you unzip the thumb drive download b4 installing on tv.
Posted on Dec 29, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 14 Answers
SOURCE: I can't turn my TV off with the Verizon FIOS universal remote.
Try the following codes. I know you stated that you were given codes so ignore any that you already have tried:
Verizon FIOS
Vizio 0891, 0912,1783
Alternative Codes
1758, 0178, 1756, 0128, 0117, 1017, 1078, 0030, 0056, 0205, 1292, 0057
Posted on Apr 01, 2009
When in antenna mode why does it freeze then turn off and come back on in HDMI1 mode?
[PDF]USER MANUAL - Vizio
www.vizio.com/documents/downloads/hdtv/.../UM_E550iB2.pdf
VizioAny other voltage than the specified voltage may .... Do not locate the antenna near overhead light or power circuits, ..... the instructions that came with your mount. ...WIDE. Switch the display mode. MUTE. Turn the audio off or on. BACK ..... Zoom. Normal. Note: Aspect ratio settings may vary by Input source. HDMI-1. HDMI- ...
[PDF]USER MANUAL - VIZIO
cdn.vizio.com/documents/e40c2/um-e40c2.pdf
setting and this is the setting in which power savings will be .... electric shock, do not perform any servicing other than ... connected to the TV, make sure that the antenna or cable system .... Locking and Unlocking the Custom Picture Modes ..... ...... .....BACK. Go to the previous on-screen menu. MUTE. Turn the audio off or on.Missing: freezes
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Jan 21, 2016 | Vizio E420VA 42 in. LCD HDTV
Vizio M550SV no sound. Is there an audio card or does the main board have to be replaced?
See page 8 here:
http://cdn.vizio.com/documents/downloads/hdtv/M550SV/991UG_M420-470-550SV.pdf
From the top
- HDMI - both Audio and Video come from device via one cable.
- RF Coaxial (aka CATV) - both Audio and Video come from device via one cable.
- 15 Pin Dsub (they are calling it RGB), Video comes from this cable and Audio is from a dual 1/4" plug (looks like a headphone wire at both ends).
- Component (this is true RGB) uses RCA type cables - two sets of cables, cable one has 3 RCA at each end and they are color coded, as follows Red/Green/Blue, cable two has two RCA color coded as follows White/Red. Cable one is Video, and cable two is audio, total of 5 connections at source and 5 connections at tv.
- Composite AV - one cable set, coded as follows - Red/White/Yellow, Red/White are audio and Yellow is video.
Hope this helps.
Nov 25, 2014 | Vizio Televison & Video
Gv 42l power blue screen no signal
Yes, a cap will rarely cause this issue.
If blue screen set is ok power wise.
If blue when connections are made to rear inputs also it means it is not the tuner in the set---a good idea is to hook a DVD up, turn it on and then the set--select that input with the DVD already on--
That aside you may want to make the effort to call Vizio and see if this is a known issue or if a software upgrade is available for this issue.
If I had to "guess" it will be the main board that processes all signal inside the set.
Do some research with GOOGLE by model number "known problems" blue screen only etc.
Apr 01, 2012 | Televison & Video
Have a vizio vx 42l on the bench. amber light only no power up have my standby 5vdc and my 3.3vdc power button is sending a high pulse to the main mod but i dont get pson to the power supply mod suspect...
This is your mainboard needing replaced! Simple as that!
The main sends the pson signal and without it...you have a dead tv.
Please rate if this helped :)
Mar 10, 2011 | Vizio 42 in. LCD TV
I have a 42 inch Gallevia model GV 42L. When TV is initially turned on blue screen comes up for about 2 seconds, it then goes black and a screeching noise comes through both speakers on the TV. No...
The power source has failed - the sound is the source that autooscillates because even its protections have been damaged and are no longer capable of safely shut it down.
It's a big failure so call a repairman, ther's nothing more you can do.
Aug 31, 2010 | Vizio SV470XVT 47 in. LCD TV
Guide button only works for curent program (first push) . Second push should bring up full program menu, but instead it just goes back to tv show.
I had the same problem with my 37L and 42L Vizio TVs but my 26w vizio TV guide works perfectly. on 12/28/2009 I called vizio about the problem and they said that Vizio lost a law suit with a company (tech didn't tell me the company name) that said that Vizio did not own the "TVGUIDE" technology b/c the other company invented it first. So, Vizio was forced to turn this feature off in their new TV's so that's why my guide button with older Vizio 26" TV (bought in 2007) works and my newer 37" and 42" Vizio TV's (Bought in 2008) do not even though the instructions are still in their user manuals which the tech said will be removed in future user manuals.
Jul 07, 2009 | Televison & Video
Vizio 47 xvt.audio comes on but no video.no response to remote.
So power button on TV and remote control doesn't turn it off? May also be set on mute and remote battery needs changing.
Dec 21, 2008 | Vizio SV470XVT 47 in. LCD TV
Vizio vp50HDTV10A Plasma Vidio and Audio on and off
Odd problem for this model.
If:
* you are certain the popping is coming from the speakers and
* the video and audio come back on after going out (without reset) then
the issue will be with the main board and will need to be replaced.
Call Vizio customer service, they extend warranties sometimes.
Dec 21, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Jan 31, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
