Question about Canon PIXMA MX850 multifunction InkJet Printer
How do I print a transmittal report after each fax sent?
  • hazelgracie Apr 21, 2009
    Well that would be wonderful if it worked!! My model is actually MX860 and when I go to the Fax Menu....there is no TX report under the print list menu. I'm stuck
  • hazelgracie Apr 22, 2009
    Thank you very much!! I was misunderstanding from the git-go!! I thought I would find the TX report setting in the FAX menu.....nope....it's in the COPY menu!!!
    Thanks again!!!!
  • Canon Master
  • 4,338 Answers
Press the Menu button; use the right or left arrows to select device settings. Use the up or down arrows to select Fax Settings. Then TX settings.
Select TX report, then select to print a transmission report after each transmission, then select attach TX image. (This will attach the first page of the fax).
TX report Sets whether to print a transmission report after each transmission.
When Print error only or Print for each TX is selected, specify the following.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Apr 21, 2009
  • JDTec
    JDTec Apr 21, 2009
    ok let me gat back with the MX860 procedure
  • JDTec
    JDTec Apr 21, 2009
    Very similar to the above:
    MX860
    Press the Menu button; use the right or left arrows to select settings; press ok .
    Use the right or left arrows to select device settings; press ok. Use the up or down arrows to select Fax Settings; press ok.
    Then Transmission settings : press ok
How do we set Samsung pro express M4580FX to do auto fax sent status and confirmation after each fax is sent (rather than printing reports)
dear
the sent report can be disabled at FAX SETUP.press menu and scroll to enter fax setup scroll to display report enter here to enable or disable the report. the sent report only display for short time after sending the fax. also you can take a print of journalreport.
Thanks.
Mar 02, 2015 | Samsung Office Equipment & Supplies
Fax confirmation
most printer in the market has the same standard setting for the fax.
u can set the report many types for many user's purposes, some people want to save paper, save ink/toner, so they dont need report if the fax is sent but only print report if the fax is not good(NG or not sent)
it can be set to:
report off--means report will be print out only if the fax is NG
report off+image--means report will be print out if the fax is NG + the image of the page that is not sent(so we know which page is not sent through the image)
report on+image-- every fax activities( sent or not sent) will be reported, which is not recommended
etc....
how to set is depends on your printer, just go to the menu "FAX" and look inside the menu.
Jul 08, 2014 | Epson Workforce 520 All-in-One Color...
How to print fax sent report
To print the fax sent reports, press setup on the printer, then press "Print Report", then select "Fax Error Report". Select the option you want (Probably "On Fax Send" in your case) and it should work from then on.
May 11, 2012 | HP Officejet 6500 Wireless All-in-One...
Does my printer give a confirmation after faxing is completed?
Normally if i fax is sent, it will just give a message as Fax sent or it wont give any error.
But if you want to get a confirmation whether the fax is sent or not, you can print a fax confirmation page on ever fax sent or received or both.
Press the SETUP button ( menu )
Scroll till you find Print Report - Press OK
Scroll till you find Automatic Reports Setup - Press OK
Choose Send Only - Press ok
Regards,
Ron
Mar 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Confirmation page shows zero pages sent. Is there a way to set to show the number of pages sent
I would first test a fax to see if it completes on your end then is received on it's entirety on the receiving end. Then print a fax transmittal report to confirm. Once that shows success, print your polling fax report and verify.
If it says zero pages sent, chances are the fax failed.
Jan 14, 2010 | Brother IntelliFAX 4100e All-In-One Laser...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Konica Minolta C250 Scanner problem
To print the transmission report:
1. Press the [Fax/Scan] key to display the Fax mode screen.
2. Touch [FAX Menu].
3. Touch [TX Report] on the Set 1 tab.
4. Select how to output the report, and then touch [Enter].
– Default: The transmission report is printed according to the previously specified method.
– ON: The transmission report is printed with each transmission.
– If TX Fails: The transmission report is printed only if the fax could not be sent.
– OFF: The transmission report is not printed, regardless of the transmission result.
Feb 05, 2008 | Konica Minolta bizhub C250 All-In-One...
Canon PIXMA MX850 multifunction InkJet Printer Logo
356 people viewed this question
old marine
old marine
