Question about Philips ProScreen 4750 Impact Multimedia Projector
Philips ProScreen 4750 - Ghost red image
Has I sad in the subject, my Proscreen projector has a ghost our shadow image in red color. I have tried to solve it with the brigtness and the contrast but it dind't help. Is there any way to cabibrate it? Thanks Rui Pereira Portugal
SOURCE: how do you get the
there is a door next to the input panel you will see 2 silver screws that you can use a flat head to unscrew once you take those out you will see another 2 screws that you will need to remove as well once that is done there is a flap on the bulb housing with a hinge that you need to pull up then tug on it and it will slide out once you do that you will get the bulb in the housing you will need to take the wires off the bulb one will be a nut the othere will be a torx screw remove those and there will be a metal long piece that is holding the bulb in plaace yppu have to pop that out then the bulb will slide out
Posted on Jan 09, 2009
0 characters
1 Points
Convergence phillips proscreen
The adjustment requires disassembling the projector. It's not really something that should be attempted in the field.
Sep 08, 2014 | Philips ProScreen 4750 Impact Multimedia...
Ghosting Image
may be the lens has alignment the lens
of your projector there a adjustment
try to adjust!!!
Sep 21, 2008 | Philips ProScreen 4750 Impact Multimedia...
The projector does not operate the "lamp" led blinks in green and turn red after one minute. The switch on button does not replied.
either it's overheated or needs a replacement bulb.Do not cover this unit with anything as it will prevent cooling down..
Jul 27, 2009 | Philips ProScreen 4750 Impact Multimedia...
Dark screen
Dear Bob,
Pls contact me at the soonest , i can solve this and i am willing to buy your unit.
May 23, 2008 | Philips ProScreen 4750 Impact Multimedia...
How do you get the bulb out of the Phillips ProScreen 4750?
Hi there
There should be a lamp door at the bottom of the Projector that you have to unscrew before you will be able to take out the lamp.
May 19, 2008 | Philips ProScreen 4750 Impact Multimedia...
Picture off and shadow of back images.
Hi Grim159
I've had this once on a Epson Projector and the only way I could this right was by replacing the Mainboard.
Hope this is of help.
Apr 22, 2008 | Philips ProScreen 4600 Impact Multimedia...
Double image or shadow image
We recently had the same problem with our church projector and we too had just changed the lamp. I read somewhere while searching for an answer that if the cable input is loose it will cause double vision of the text. Sure enough, the cable was loose and after tightening the text cleared up immediatly.
Dec 26, 2007 | Philips ProScreen 4750 Impact Multimedia...
Your convergence might be out.Go to convergence settings and try the setting and it can be done electronically.
Jan 20, 2007 | Philips ProScreen 4600 Impact Multimedia...
Philips ProScreen 4750 Impact Multimedia Projector Logo
115 people viewed this question
Top Philips Multimedia Projectors Experts
Lawrence Oravetz
Frank Russell
Frank Russell
Are you a Philips Multimedia Projector Expert? Answer questions, earn points and help others
