Question about Konica Minolta magicolor 5430 DL Laser Printer
Keeps saying: DRAWER OPEN Tray 1
This has been sitting for awhile (a few years actually). First while we were moving out to hook it up and use it again, someone opened the side cover and knocked the spring off casuing the rollers to nearly fall out. Once I get everything re-aligned and back together, I tried plugging it in and turning it on. I get the messages that the toners were all low. I know they were more then half full the last time I had used this printer, so I took them out back and tried shaking them. After putting them back in, still getting the same warning, but now it is telling me the paper tray is open. This is a 5430DL and there is only one tray on it. Is there a sensor I need to clean? and once I get that problem taken care of, what about the toner? Does it harden and become unusable after sitting for such a long time? Tips and suggestions are greatly appreciated.
  • Konica Minolta Master
  • 6,161 Answers
AS for toner use OEM not third party.replace them. as for the paper draw check the sensor and tab that accurate the sensor telling the machine the draw is closed. might be broken or the sensor got hit when you re-installed the roller.
Posted on Mar 13, 2016
4 Suggested Answers
SOURCE: Not noticing paper
I took an envelope, folded in the end to triple its thickness and placed it in the middle of the paper tray underneath the very last page. This pushed the center of the paper up more and it had no problem detecting or getting hold of the paper. Have to be sure the paper supply tray is full though. When it gets to the last five or seven pages it has difficulty again. It's a nontechnical fix, but it seems to work.
Posted on Feb 25, 2008
  • 55 Answers
SOURCE: Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Posted on Apr 25, 2009
Riztech
  • 731 Answers
SOURCE: Error light flashes ... Message: Open the printer
Hi Connie,
If you take out all the toners you will find a contact at the bottom where the chip from the cartridges touch , these three springs work loose.
If you notice them loose, you need to take the black clip out split it and solder them back on; that will sort the problem out.
CLICK HERE to download Service Manual for future reference (Its for MC 2300, works for 2400 series as well) Troubleshooting with service manual is on Owners risk.
Regards
Riztech
Posted on Nov 19, 2010
FL 8350 CD Player. Disc drawer will not open. Getting error message
Most likely a belt has stretched and will not now move the tray. This happens of units more than 2 years old usually.
Dec 26, 2012 | Harman Kardon FL8350 5-Disc CD Changer
My PS2 slim has been sitting in a drawer for awhile. Today, I went to go hook it up and none of the disks i put in will spin & the messageon my tv says "There is no data" Help.
It sounds like your lens is dirty.take it to a gamestop or electronic repair shop should be like a $15.00 fix tops.
Hope this helps.
May 01, 2011 | Video Game Consoles & Games
I want to put 8 1/2 by 11 paper in top drawer (#1) and use 8 1/2 by 14 in lower drawer (#2) I do put the papers in correctly, but it does not recognize drawer #2 as anything but 8 1/2 x 11. How do I...
First you have to put a little wheel (in front of the tray) in the correct size and format of the paper.
Than You have to see in the menu what is selected.
User tools.
System sittings
Tray paper sittings
(change to your needs)
Feb 18, 2011 | Ricoh Aficio MP 1600L Black and White...
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
Our xbox 360 elite keeps telling us to open tray drawer after inserting a disk. We tried 3 diff disks get same thing. Worked fine last pm
This is one of two problems, both involving your laser.
1: the laser is dirty, get a laser lens cleaner and run it through your xbox a few times and see if that helps. You can also get a can of compressed air and carefully spray it into the open tray slot.
2: Your laser has died, at which point your only option is to call Microsoft and ask them for a repair order. Sorry :(
Aug 13, 2010 | Microsoft Xbox 360 Elite Console
Repeats "empty coffee grinds drawer". drawer is empty.
Check the area behind the draw there might be some ground coffee preventing the tray from sitting correctly.
Jul 05, 2009 | Saeco Royal Professional Espresso Machine
When game put in screen says tray is open?
something may be blocking the drive door such and paper or dust build up. try pushing on drawer a little after it shuts to see if that helps
Apr 18, 2009 | Microsoft Xbox 360 Console
Faulty dredge drawer sensor
remove drawer and drain tray, there may be some coffee grounds on the back of the machine where the drain tray sits, preventing the dregs drawer from sitting properly.
Apr 10, 2009 | Gaggia Syncrony Espresso Machine
Keeps "jambing" - won't fully pick up the paper and move forward
I work on these on a daily basis, the standard tray you are using is "Tray 2", which is the drawer tray on the bottom of the printer. If you open the front flap of the printer you will see a place where you can rest paper, This is known as "Tray 1". Remove Tray 2 and Try printing from Tray 1, (you may have to go through your menu items and make Tray 1 your default tray) If the printer is printing fine from tray 1 then the problem is one of two things.
1. Your rollers are worn
-you'll see one in the middle of the drawer tray when you pull it out
-the other one is located in the tray housing, remove tray 2 from the printer and slide your hand along the roof of the tray housing, you will be able to see/feel another roller.
Replacing both these rollers does the job 90% of the time.
2. The other thing that causes this problem is that the lifting mechanism in tray 2 is broken. This is usually not the case, and it is recommended that you replace the rollers before trying another repair.
Rollers should feel spongy and rough, they become hard and smooth the more they get wore down, until they are no longer able to catch and pull paper.
Jan 26, 2009 | HP LaserJet 4050 Printer
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Konica Minolta magicolor 5430 DL Laser Printer Logo
89 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
