Question about Makita DA4000LR Electric Angle Drills
Makita angle drill complete chuck part no.stex 122177 required.
rowdy45176
  • 2176 Answers
SOURCE: chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
Posted on Dec 20, 2008
rowdy45176
  • 2176 Answers
SOURCE: chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Posted on Jan 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: makita 6408 drill motor. can't see how to replace the chuck.
If you have the 6408 as listed the spindle is threaded and you are correct there is no retaining screw. What you would need to do is find a bent handle allen wrench about the size of the chuck capacity 3/8" and insert the shorter end in the chuck and tighten. put the chuck on a block of wood or workbench and position the long end at about a 30 degree angle in the counter clockwise position and strike it with a hammer, this might take a couple hits. If this is not a 6408 let me know and I will look at the tool for you and see what you got.
Posted on Jan 23, 2009
  • 100 Answers
SOURCE: Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Posted on Feb 16, 2009
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
How do you put the black chuck cover back on
It sounds as thought you have a keyless chuck on your drill. The cover is not meant to come off. You will have to replace the chuck.
Apr 18, 2014 | Makita 18V LXT Lithium Ion Cordless 3/8...
Makita 6301LR right angle drill How to change speeds within the right angle assembly ie how to get the damn thing apart! It's off the drill body. Now how to proceed? Also: what are the hi and low...
OK first you need to remove the drill chuck from the spindle, you should have an allen wrench and an open end wrench, remove the chuck retaining screw it is left hand thread, after removing there is a drift pin that is inserted in the hole of the drill chuck and the wrench fits on the hex of the spindle, place the assembly on a block of wood with the pin at about a 30 degree angle so that you have the wrench as a support and would be hitting the pin counter-clockwise to loosen and remove, after removing the chuck screw it onto the OTHER spindle and tighten in the opposite manner, replace the screw and reinstall the RAD onto the drill, this will change the RAD (right angle drive) speed. Let me know if you need more assistance.
Jun 17, 2011 | Makita Drills
Makita HP 1640 hammer drill chuck loosens grip on drill while drilling
Sounds like the chuck is worn, happens frequently when used often. Here's the link to Makita, their contact info should get you some answers as to what part number is needed as well as the closest location to you for service if required. Hope this helps.
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=316372
Jan 14, 2011 | Makita HP1640 58Inch Hammer Drill
Got the screw out of my chuck but still cant get the chuck off does it screw off or does it just pull off after screw is out on a makita bdf452
What you need to do is shift the tool to low and the drill only position. Find a bent handle allen wrench about the chuck capacity and lock it into the jaws. Put the chuck ona workbench or wood block with the long part of the handle about a 30 degree angle facing counter clockwise and strike it with a hammer, it might take a couple times but it will come off. The chuck is screwed on with standard threads
Aug 27, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Change the chuck on a makita DA39DA coredlesss right angle drill
look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger.
Aug 20, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Struggling to remove chuck from makita 84444d
K what you need to do is remove the chuck retaining screw LH threads and then switch the gear selector to low and the clutch to drill only. Find a bent handle allen wrench about the chuck capacity and lock it in the jaws. put the chuck on a workbench or block of wood and on the long part of the wrench have it at about a 30 degree angle and strike it counter clockwise and that should remove it. you might have to hit it a couple times
Aug 20, 2009 | Makita 8444DWDE 18V 1/2" MXT Hammer Driver...
My chuck snapped off, where can i get new chuck and angle bit
OK I assume that by chuck snapped off the spindle is broken and if so there are 2 the low side spindle is part #324170-4 and the high side is 3241699. I believe the gears are a press fit on the spindle. the complete RAD part# is193316-1 and if the chuck only is damaged that number is 193319-5 and from what I can see it is a taper fit on the spindle, I didn't see a chuck retaining screw. If you would like to view the tool go to Makitausa.com and type in your model number and you can get a breakdown and also a list of Makita dealers in your area. Good luck and let me know if you still have any problems
Feb 15, 2009 | Makita DA4000LR Electric Angle Drills
Makita 6408 drill motor. can't see how to replace the chuck.
Jan 23, 2009 | Makita 6408K 3/8" Variable Speed,...
Chuck removal
Jan 01, 2009 | Makita 6304LR 1/2" Chuck Electric Drills
Chuck change
May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita DA4000LR Electric Angle Drills Logo
302 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
