Question about Whirlpool GS460 Gas Kitchen Range
Our oven won't heat. The pilot light is out and won't re-light. We tried replacing the igniter but that didn't help. What else can we try?
  • 76 Answers
Are you sure you have the right model number? This model does not have a pilot light.
Posted on Jun 20, 2009
I have a Garland Sunfire 36 inch gas Range. oven does not come on again after reaching temp.
You probably have a bad thermocouple. Try cleaning it off with sand paper. It's the part that the pilot light is igniting.
Mar 15, 2012 | Garland SunFire SX-10-26 (Gas) Stainless...
Stoves 61gdo main oven not lighting
the thermocoupler is at fault it will need replacing if its stuck on pilot the thermocoupler heats up a small capilary tub that swiches the control to the temp regulator
Nov 23, 2011 | Kitchen Ranges
Burners work fine, pilot light in oven is on, but oven won't ignite
Make sure the thermocoupler is being heated by the pilot light flame. It could also be gunked up but you can clean it with a scouring pad, or it might need to be replaced. The thermocoupler is the most likely cause because if it isn't heated then the gas valve will not open up and no gas will flow to the burner. Since your pilot light is on then you do have gas to the valve.
Aug 28, 2011 | Ovens
Our MAGIC CHEF gas range has a pilot light that comes on, the ignitor comes on, but the oven does not work heat. Any ideas would be appreciated.
First off, decide which you have, a pilot lite or an igniter coil. In electronic controlled units, when the oven won't light, as long as there's gas available, 98% of the time the igniter is bad, even though the old one may glow and seem to be very bright, it could have a small hairline crack in the ceramic, which would not allow the proper amount of electrical current to travel to the gas oven safety valve, which would then make it open and release the gas. A new igniter works almost every time.
Jul 03, 2011 | Magic Chef 31000 Gas Kitchen Range
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 | Ovens
Oven does not work: pilot light out? How feasible (how dangerous) to try to relight pilot light? T Phillips Winston-Salem, NC
Actually, your oven probably doesn't have a pilot light at all. In order to ignite the oven, it has an oven igniter. If you open the broiler, look up on the "ceiling" of the broiler to the back of the burner. There, you'll see a white block. That is the igniter. What it's supposed to do is heat up (electrically) and when it heats up enough, the gas valve turns on and the oven lights. What happens with these, is that the heating element on it opens from years of use and must be replaced. Inside the broiler door (usually) is the stove's model and serial numbers. Write them down and visit your local appliance parts store with those numbers and they'll give you a new one. (Usually around $30-$45 or so.) Also, you can usually change the igniter from inside the oven by removing the bottom drip plate, so that'll save your back a lot of straining. :)
I hope this helps and hope you have a wonderful holiday season!
-Jason
Dec 22, 2010 | Whirlpool GS460 Gas Kitchen Range
When I turn on the oven it doesn't ignite. There's no gas smell and I see that the oven pilot light is out. I've tried lighting the pilot but that doesn't work. I assume a part needs to be replaced but...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
sd544
Apr 15, 2010 | Kenmore 75012 / 75014 Gas Kitchen Range
I have a Maytag gas over/stove, Model number MGR5755QDW. The broiler heats, but the oven does not. What are the possible causes and how do I troubleshoot?
If you are having problems with the oven, the first thing to do is figure out if you have a pilot light system or a glow bar system.
Problems with the pilot light system.....The flame has gone out, re-light the pilot. The pilot flame will not light - possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's a internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Problems with the glow bar system.....You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works -click here.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Jan 26, 2010 | Kitchen Ranges
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Maytag/Magic Chef CGR1110ADW gas range
heatman101
adfaf
Dec 09, 2008 | Magic Chef 31000 Gas Kitchen Range
Whirlpool GS460 Gas Kitchen Range Logo
160 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
