Question about IBM ThinkPad R40 2681
I just bought a used ibm think pad laptop
And it wont boot it readsno operating system found
  • ruben_faison Apr 21, 2009
    PXE-E61: MEEDIA TEST FAILURE
    PXE-MOF: EXITING INTEL PXE ROM
    OPERATING SYSTEM NOT FOUND
    THIS IS WHAT COMES UP WHEN I TRY TO RE-START MY PC
  • IBM Master
  • 4,806 Answers
Hi there.
If you have just bought the laptop chances are the operating has been removed to you cannot see any data that used to be on it, you need to go and purchase a windows OS that the laptop was built for (i'm guessing XP) and re-install the operating system again.
Good luck and thanks for using FixYa!!
Posted on Apr 21, 2009
  • Lee Hodgson
    Lee Hodgson Apr 21, 2009
    Ah, i see, its trying to boot from the LAN so boot order is wrong, you have to into the bios to change the boot order.
    While the computer is just starting up hit F1, this will get you into the bios, you can change the boot order there you need to chose the hard drive or HDD as first boot device , remember to save the settings before you exit the bios.
    The computer should now boot into windows.
    Good luck and thanks again.
Ibm think pad 240 x
There are many error messages that appear on your screen that make your heart flip, but I suppose the one that is certain to bring you out in a cold sweat is when you boot up your pc and a message appears saying Operating System Not Found!
You have good reason to get into a cold sweat with this error message because, nine times out of ten, there is a serious problem and that problem can be one of many, such as:
-The BIOS hasn't detected the hard drive
-You have an incorrect Master Boot Record
-The hard drive itself is damaged
Jan 28, 2012 | IBM Computers & Internet
I deleted everything on my ibm thinkpadr51, when i turn it on it says initializing but then it says media test failure,check cable. then exiting intel boot agent and operating system not found , how do i...
if you have completely deleted your operating system your note pad will not start as it needs this for instruction you will have to reload/reinstall the operating system
Oct 02, 2011 | IBM ThinkPad R51 Notebook
Operating system not found
On my Lenovo ThinkPad Windows 7 laptop, I have got "Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
May 20, 2010 | IBM ThinkPad R30 2656 Notebook
My Think Pad Won't Boot Up When I Turn It On
Check the link given below for more details:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4YLR6R
If you want more troubleshooting then provide more details like error message, what Operating System etc.
Good Luck!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | IBM ThinkPad T21 Notebook
I bought a used ibm think pad I need to bypass the log in and pass word.
in oder to do this u must have operating system cd ,if you have one
try to chage the boot oder from hardisck to cd rom .once u do that put the cd into the computer and try to boot the computer from cd ,while doing this it will give you a promt to shift the setting to factroy default do that and your issue would be resolve
Jul 09, 2009 | IBM ThinkPad R52 Notebook
IBM Think Pad TDD
reinstall the OS, but first back up you files. you can remove the HDD located at the bottom of the Laptop. buy a cheap 2.5 inch usb to ide/sata enclosure and place your hdd on it. use a PC to transfer your files. then format the HDD. reinstall the HDD to your laptop and install the OS.
Jul 06, 2009 | IBM ThinkPad T22 2647 Notebook
I have an Ibm think pad laptop and I went to turn it on the other day and the ibm screen comes up with press F12 for bios set up on bottom but dosent go pass this screen no cursur and no sound got any...
Use IBM boot disc that was supplied with your computer. If that doesnt work use the operating system disc that came with it. If you have neither of those and the operating system was installed from the factory on a different sector of your hard drive try to start the computer up 3 times in a row and the computer should say safe boot or even boot from diagnostics etc. If you dont see any of that at all possible hard drive failure occured and you will be looking at gettting a new hard drive $50-$150 depending on size (newegg.com). Do you have the operating disc or not? if you dont then you will need to call IBM to see if they can send you a disc, if thats a no go then you will need to purchase one (newegg.com).
Jun 03, 2009 | IBM ThinkPad T40 2373 Notebook
Put new hard drive in ibm 570
you need to install the windows operating system to the new hard drive and transfer your files ...
if you still have the CD installer that comes with it when you bought the computer..use the CD with label operating system..then after you install the windows..use the cd with label drivers and application
Mar 15, 2009 | IBM Computers & Internet
My IBM Think Pad T30 showin working on AC with out powering..
If it's not finding the operating system, and you'va ran the recovery cd, then the problem is going to be that the hard drive has failed and will need replaced. In order to double check and make sure it's the hard drive, run the recovery or operating system disc, and reformat the hard drive. If the hard drive will not format, then it's bad.
Aug 31, 2008 | IBM ThinkPad T23 2647 Notebook
MY IBM T43 fails to boot
Take out the hard drive and see if the laptop still shuts down. If it doesn't then your hard drive might be the issue. You can also try reseating your memory.
Dec 26, 2007 | IBM ThinkPad T43 Notebook
IBM ThinkPad R40 2681 Logo
143 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
