Question about Motorola Walkie Talkies 2-Way Radio
Need to program in 1-10 frequency...is this possible ?
Hi, I have a motorola TA200 and my motorbike club use 1-10 frequency but I cannot appear to change the frequency to match there radio's.... can anyone help
  • mike_rhodesp Apr 22, 2009
    Hi, thanks for your question, they are all various radio's but they are all of the radio's are able to go to Channel 1 CTCSS 10 and I would like to know if it is possible to change my TA200 to enable me to have the ability to access Channel 1 CTCSS 10. Thanks for any help. Cheers MIKE
  • eradiostore
    eradiostore May 11, 2010
    What type of radio is the club using which you are trying to match?
  • Motorola Master
  • 1,654 Answers
Okay, I'm going to attempt to assist you with this. If your TalkAbout 200 has a screen showing your channel number and a smaller number in the upper right. It is possible your radio could be programmed to match another TalkAbout or FRS (family radio service) style radio. I cannot find an owners manual in English for the T200. Here is one you can translate from Czech http://www.cbradio.cz/doc/Motorola/PMR%20TA200/manual.pdf (Simply copy and paste this into a google search with the word translate in front of it.) It will give you the instructions for reprogramming your "interference eliminator code", aka CTCSS. Your radio has 14 built in frequencies. From your explanation I would assume you need your BIG number to be 1, and your small number to be 10.
If your TalkAbout does not have a screen, you will not be able to do the CTCSS #10. It is a CSQ model only.
Sidenote: If the other radios you are wanting to talk to are NOT FRS-type or TalkAbout radios, your radio will not match them.
Posted on Apr 22, 2009
How can I get my Motorola CLS1110 to talk to my Baofeng BF 888s?
The CLS has preprogrammed frequencies. The Bao can be user programmed. If both are Uhf, the Bao must match the CLS unless one of the CLS frequencies is already in use in the Bao. So, are you already using CLS and adding radios? You need the actual frequency and tone code. If you do not understand, contact a dealer like us, local is even better! Channel 1 is only an indicator, not a frequency. radiodude365@yahoo.com
Mar 01, 2015 | Motorola Radio Communications
Honda TA200 Phantom valve clearances
Hi, Mrsmith for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda CTX200 valve clearance
Phantom valve clearance check and adjustment
Honda 86 87 TA200 FATCAT Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow TA200 Owner Manual
Dec 19, 2013 | Honda Motorcycles
Can I program an Icom F22 to connect to a Motorola TA200?
The two radios have no frequencies in common.
F22 = 446.00625-446.09375 MHz
TA200 = FRS frequencie in the 462 & 467 MHz range
Best regards/
May 12, 2012 | Motorola Walkie Talkies 2-Way Radio
Can two different style motorola 2 way radios be changed to same frequency
Hi Kate,
The short answer to your question is: no, or "not readily". Here's why:
The Motorola 4900 radio operates in the FRS (family radio service) and GMRS (general mobile radio service) in the UHF band. This radio will work with any other FRS / GMRS band radios (no reprogramming of transmit and or receive frequencies is possible for these radios). The trick is that the numbering of the channels may differ from brand to brand ie: Ch1 on your Motorola may not necessarily be Ch1 on a Midland radio or other brand. A complete list of the frequencies and channel assignments for FRS /GMRS can be found on Pg. 17 of the manual. It is important to note that without a valid GMRS license, you are prohibited from transmitting on the GMRS only channels (Ch 15 through Ch 22). The combination GMRS/FRS channels (Ch1 through Ch7) and the FRS only channels (Ch8 through Ch14) are for individuals and family members that do not have valid GMRS licenses. If this is you, you should limit your transmissions to Ch1 through Ch14 only, as FRS does not require a license in the US. Unlicensed use of GMRS only Ch15 through Ch22 can result in fines and imprisonment if caught by the FCC.
Further complicating the issue are the so called "privacy tones". This is simply a very low or "sub-audible" frequency that is sent whenever transmitting. Motorola calls these "Interference Eliminator Codes". When another radio receiver is set to listen for a particular privacy tone, it stays silent until a transmission with the exact same privacy tone is detected. Again, these tones are listed in no particular order, but are generally listed as 1, 2, 3, etc. or a, b, c, etc. instead of the actual frequency in hertz. You can selectively set your radio to transmit & receive one of the 38 codes or, set the code to "0" to communicate with radio that do not offer these privacy codes - or does not use the same frequencies for these codes. You can read more on Motorola's codes on Pg. 19 of the manual.
The Motorola CP200 radio on the other hand is a commercial radio, and requires computer programming with Motorola software. The CP200 is offered as both Low & High sub-banded VHF and Low, Mid & High sub-banded UHF radios. You would need to have a CP200 that is designed to accept the Mid UHF band (438Mhz - 470Mhz) frequencies in order to program the 462Mhz & 467Mhz FRS / GMRS frequencies into it. The final obstacle would be what is called "FCC Type Acceptance". The CP200 is probably NOT Type Accepted for transmitting FRS/GMRS frequencies, and as such the Motorola dealer doing the programing might balk at putting them in. You can read a spec sheet on the CP200 here.
I hope this helps & good luck!
Feb 29, 2012 | Motorola Radio Communications
I own Motorola GP300 2 way radio.I need some device for changing frequencies as I needed.What equipments or any softwares to complete my need and their prices?
to change the frequency of your radio,you need programming cable/programming sofware,but this is only for authorized Motorola dealers,other options go to your nearest motorola dealer,along with your licensed frequency ,they'll program it,thank you
jack
Dec 02, 2010 | Motorola GP300 Compatible 2 Way Radio...
How could i program/change the freq of my motorola gp2000 manually
I don't think that you could program/change the freq of your Motorola GP2000 manually since newer Motorola radios today everything is done by computer and programming sotfware. You need to have software for GP2000, radio interface box ( RIB) and programming cable for GP2000 radio and these devices are not cheap. The best way is to contact a local repair shop to have it done for you or find a two-way radio technician, he could do this if he has all the test equipments required.
Radcom907
Oct 21, 2010 | Motorola GP300 Compatible 2 Way Radio...
Motorola XTNi off frequency
There are several ways:
1) Customer Programming Software (CPS)*
Allows users to perform various programming
functions. Plus, the CPS software provides access
to new features such as Radio Reporting to
manage cloning and radio profiles, Manager Lock,
Power Select, and Time-Out Timers.
* CPS is available as an optional accessory, including required USB cable.
2) Easy Cloning
Quickly copy settings from radio to radio with
either the Radio-to-Radio Cloning Cable or the
Multi-Unit Charger accessories. (Both sold
separately.)
You should be able to purchase any of this software/equipment from your retailer where you purchased the radio.
Best regards.
Dec 03, 2009 | Motorola XTN 2-Way Radio
Can Motorola TA200/T5622 work with newer T5000?
A 22 channel transceiver is an American system call FRS/GMRS radios which are actually illegal in the UK and rest of europe. They use different frequencies completely and will not work together on you other PMR radios.
Mar 15, 2009 | Motorola Talkabout T5720 (7 Channels)...
Motorola talkabout 200
Here is a link to the TA280 manual, which is similar to the TA200, http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T280_User_Manual.pdf
Funny thing, I haven't found the TA200 manual in English. Here it is in Czech: http://www.cbradio.cz/doc/Motorola/PMR%20TA200/manual.pdf If you do a google search, you can find the page and have it translated. I'll keep looking, and if I find it in English, I'll repost.
Nov 09, 2008 | Motorola Talkabout T5720 (7 Channels)...
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola Walkie Talkies 2-Way Radio Logo
514 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
