Question about Insignia IS-PDVD10 Portable DVD Player
I have a portable dvd player and the disc inside the player that spins fell out and is lost. Is there any way to replace this part?
    President:
  • 814 Answers
If this unit is under warranty call this number for technical help on how to return the unit for a new one. Service: 1-877-467-4289. If not call this number for help getting a replacement part. Parts: 1-888-237-8289. Hope this helps you with you problem.
Posted on May 10, 2009
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Tip
Player reading invalid disc and disc is not spinning
My dual screen dvd player was reading invalid disc and disc was not spinning. Took player completely apart and white gears had dirt in them. This was preventing the player from spinning. Used dust remover and cleaned the whole inside and now it works great.
on Sep 01, 2008 | Durabrand DUR7 Portable DVD Player
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Looking to replace the small round disc that holds the dvd in-place on the dvd player. Ours was loose (unknowingly to us) and fell out and was lost. Can it be purchased from Proton or Radio Shack or...
You can buy it on your local electronics supply. Usually it is available in the market together with the motor. See my tips to follow instruction dis-assembling the motor. Thanks for using fixya.
Jan 26, 2011 | Protron PDV-288 7" LCD Portable DVD Player
The player fell from a height of 3 feet ,. Its getting on but not reading ? what to do ?
HI:
Unfortunely most of the time when you drop a portable unit, things get knocked loose or in the worse case a cracked Circuit board from the empact, shake the unit to see if you hear any rattling inside the case, if so then there may be broken mechnical or plastic parts inside. put your ear close to the unit, after inserting a disc, and listen to the spindel motor rev up. You can also here the pickup tap slightly against the disk if you do not hear any motor spinning then the clamper may not be down on the disc or laser is not working, a non working laser could mean a cracked board.
Nov 10, 2010 | Sony DVP-FX810 Portable DVD Player
Doesn't play any dvd or cd
you need to see if the disc is spinning inside the unit, if it is then you need to either clean the laser with a clean cotton tip or replace the laser, if the disc doesnt spin, it may be the spindle motor(held within laser assy,which is easier to replace) or it could be the mpeg printed circuit board. Good luck.
Sep 26, 2009 | Durabrand DUR7 Portable DVD Player
Portable DVD player .disc error unit spins but says says no disk
Likely to be a classic laser failure. It will require technical person to replace it - try starting with the point of sale and see about warranty etc
Dec 17, 2008 | Televison & Video
Phillips portable player PET724
I had the same problem with my PET724. I tried cleaning the lens, letting the battery run dead, even beating on it but nothing worked. When I was cleaning the lens again with some cleaning agent I accidentally slid the laser head as far away from the center as it would go. When I loaded another disc it has worked fine ever since. I have played at least two dozen discs so far with no problem.
Hope this helps.
Apr 19, 2008 | Philips PET724 Portable DVD Player
Disc not spinning
It could depend on the type of media you're using. I noticed that certain types of self made dvd's don't play in this player.
Apr 01, 2007 | Polaroid PDV-0823A Portable DVD Player
Insignia IS-PDVD10 Portable DVD Player Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
