Question about Mitsubishi VS-55707 TV
Tv shuts off
My set will shut itself off and when you try to turn it back on it just clicks but won't turn back on. When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times. during 15 mts of your sitting do you get sound & less brightness then problem in video or luminance section. if picture is dim & color will fade in and out at times then possibility of crt is getting less voltage on g2. if set is old then there is a possibility of crt getting weak. but if the above things are not there then problem in power supply. good luck
Posted on Sep 23, 2007
SOURCE:
I bought a laptop on the 16/12/2017 I played for 4 hours this morning I could play it for 15 minutes then it shut down I tried to factory settings
Plug it into the mains. It ran out of battery power.
Or
You had it sitting on your lap, or on the bed or on a cushion, you covered the intake grill for the cooling fan, and the processor shut itself down in Protection Mode.
You shouldn't be reformatting a computer that you only had two days. Take it back for professional assessment.
Dec 19, 2017 | The Computers & Internet
TV - Mitsubishi WD-62530 Will not power up unless first unplug from wall for approx. 15 minutes prior to turning it on or it will not power up at all).
Start with changing the capacitors that look bad on the PS board...I think you will find some that are bulged when you take the cover off, should be a easy and cheap fix
Oct 22, 2017 | Mitsubishi Televison & Video
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
1989 corvette cuts off when running for 10 minutes. starts up and shuts off immediately afterwards. sits for 15 minutes and the cycle repeats itself
could be the security system. is the key an original or one made later? the keys have a chip that must be programmed to the particular vehicle. try turning the key to on wait i think 15 minutes the turn the key off then try to start.
Jun 17, 2012 | Chevrolet Corvette Cars & Trucks
Tv remains on for about 20 minutes then shuts off by itself and won't come back on. please help
does the power indicator blink when the set shuts down? If so thats an error code let me know the number of blinks and I will assist with the reason why the set is shutting down.
Jan 20, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Basement flooded and got approx 12 inches of water in bottom of dryer let sit for a week to dry before trying when pushing start button will come on but wont continue running unless you hold button in ...
Sorry to say but you will need to replace the motor. After water gets in you can rarely save the motor no matter how long you let it dry.There is an internal over load inside the motor that is cutting out after 30 seconds and once it cools for 15 or 20 minutes then it resets .Hope you found this information helpful and thank you for using Fix ya.
Jun 24, 2011 | Whirlpool Dryers
Toshiba 27af45 turns off by itself every 15 minutes..how do I fix
I think the timer setting in your TV is broken. Try fixing this.
May 07, 2009 | Toshiba 27AF45 27" TV
Mitsubishi VS-55707 TV Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
