Question about Microwave Ovens
Plastic melted inside oven, dripping from ceiling Kenmore 721
There is a round screen on ceiling of microwave, 7inches diameter. it is like melting and dripping melted plastic down from the ceiling. question, can the round vent be removed, replaced, or what is it? The microwave is built in above the cook top.
  • Anonymous Mar 27, 2014
    inside of microwave oven dripping with water
    Scholar:
  • 126 Answers
The round peice in top of unit is a cover for the stirrer wich moves waves around for even cooking. The reason for it melting is almost certainly there is not enough paint in cavity and waves are shorting out to metal.CALL the manufacturer and depending on age of unit they may replace it free
Posted on Apr 22, 2009
Panasonic NN-CT585S Microwave Oven - door seal melting on inside - only 2.5 years old. Has anyone else had this fault or just please check where the glass meets the plastic on inside door.
The door seal is called the reflector cover. It stops particles of food from being left in the reflector, the square waveguide that is under the plastic seal.
The only thing that I think can cause that is particles of food or grease/oil sticking to it and melting the plastic. I don't think it is a fault from my experience of working with microwave ovens since 1993 for Panasonic and many other brands.
Jan 06, 2018 | Panasonic Microwave Ovens
Samsung microwave internal vent cover melted
The temperature reached a high enough value to make the plastic melt .The device ran for too long. The device ran without any substance (food) to heat.
Nov 26, 2013 | KitchenAid KHMS145KSS Microwave Oven
Inside the door is plastic covering a metal mesh but the plastic seems to be melting slowly. should I remove the plastic and is it ok for the metal to be uncovered
The screen in the door prevents microwaves from being emitted through the window, so don't remove it. If you feel it is faulty, take it to a service tech, as the door must be in good condition.
Aug 31, 2013 | LG LRM1230W Microwave Oven
Kenmore microwave oven model 721
On the link below is the list of Kenmore microwave oven model manuals starting with 721.Click on selection to download.
www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+micicrowave%2Fhood+combo+-+7218924680
Hope this helps.Thanks!
Jan 07, 2012 | Microwave Ovens
Hi...have a ge micro jvm1190sy 011 i melted marshmellow in it....it bubbled over and is now stuck in the ceiling of the micro on top of the whole metal sheet i can not clean it so there is layer...
How about boiling a small container of water and once it starts boiling. Just shut the unit off and let it sit and let the steam do the work for you. Might soften it enough to scrape it off.
Aug 23, 2017 | GE JVM1190SY/WY/AY/BY Microwave Oven
It burns thru the glass trray and melts the wheeled tray holder...
There are two possible reasons for this to occur.
1.there was dirt on the turntable and that carbonized and got so hot that it melted the tray. That heat would've melted the plastic spider as well.
2.the microwave oven was turned on with nothing. or almost nothing, in it: the glass turntable is what is known as "a matching load". That means it is there as a safety precaution, protecting the magnetron, in case there's nothing in the microwave oven when it is energized. As such, the glass turntable can get hot enough to melt. That, in turn, will melt the plastic spider.
If either of those is the case, it is OK to buy a new spider & turntable.
Mar 10, 2011 | Microwave Ovens
I have a GE HVM1750SM1SS and was defrosting some bread without seeing that there was a metal twist tie on the wrapper. In only a few seconds the plastic on the top started to melt and drip in the oven....
It sounds like you may be talking about the stirrer cover.
For some models, the owner's manual covers how to remove it. You can download GE owner's manuals and installation instructions here.
Otherwise, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 27, 2011 | GE HVM1750SMSS Microwave Oven
My microwave has melted a huge hole 17 cm in diameter in the plastic cooking cover - what is wrong with the microwave.
Nothing is wrong with the microwave, the plastic cover was either not microwave suitable or a splash of grease/oil/food was stuck to the plastic and melted it.
Jan 24, 2011 | LG LMV1630ST Microwave Oven
Maytag Over The Range Microwave: Melted glass turntable, rollers
Considering the melting pooint of glass ...
Normally, microwave travels around round surfaces (Look at the B-1 for example) If you put flat metal in a microwave, you will create sparks ... lots of em. Is it possible you have something going on with one of the wheels ... like a piece of tin foil?
At a minimum, I think id be inspecting everything inside very carefully and then give it a good cleaning.
You might want a pro in your area tale a look at this as well.
a
Oct 05, 2009 | Maytag MMV4205 Microwave Oven
E-wave KOT-152UB glass tray and turning ring melted
Sounds like some metal is involved somehow. If the unit otherwise works, replace the damaged parts. Test with a cup filled with water.
Dec 08, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Ovens Logo
878 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
