Question about Lexmark X4650 InkJet Printer
How to find ink cartridge compartment on the 4650
  • 5,660 Answers
This is the Lexmark 3600 - 4600 Series Users Guide, should you not have the user manual,
http://www.lexmark.com/publications/pdfs/2007/4650/LXDTuser_en.pdf
Just copy and paste this into your address bar, and press the Enter key. (NOT to insult your intelligence in any way. The address bar, is up above where you see -> http://www. <- at the start.
Right now if you look, you should see,
http://fixya.com/support/t2051756-find_ink_catridge_compartment
Go to the address I gave you, put your mouse cursor in front of the -> h <- in http:
Hold the Left mouse button down, drag the mouse cursor across the address I gave you. Let go of the mouse button, after the entire address I gave you, is highlighted in blue. Press the CTRL key AND the -> c <- key at the SAME TIME. Now go up to the address in the address bar. Put your mouse cursor right after the -> t <- in compartment. Press the CTRL key AND the -> v <- key at the SAME TIME. Now press the Enter key)
Give the PDF file time to fully download, before looking through it.
Page 95 shows illustrations and tells you how to do it.
If the above address does not work for you, then go here,
http://www.lexmark.com/publications/pdfs/2007/4650/en.html
Click on User Guide.
It's best to use this user guide, as it has illustrations in two tone color, and detailed instructions.
Posted on Apr 21, 2009
I am using the lexmark 4650 as a wireless, recently each page is printing but with gray lines all the way down the page horizontally.
Your cartridges probably needs cleaning. On the printer operator panel, press Setup button -> Maintenance -> Clean Cartridge. Your printer will then print a test page, forcing ink through the nozzles to clean dirts and possible clogs. You may also try to re-seat your cartridges. Or insert a different know good cartridge to determine if it's a faulty cartridge issue.
Apr 19, 2011 | Lexmark X4650 InkJet Printer
We got all new ink cartridges for our printer but it keeps saying that the toner is low and won't print. We shook them all like it said but we can't figure it out. Hopefully you can help us...
First of all, this printer is not inkjet, is a laser printer. It has toner cartridges, not ink. Was the cartridges you changed, originaly? Every cartridge has a chip and the printer recognize them being originaly. If the cartridges are not originaly or compatible, the printer doesn't recognize them and can't read the chip to reset the message " replace cartridges" and doesn't print anything.
Mar 08, 2011 | Konica Minolta MAGICOLOR 4650EN 24 ppm ...
How o I replace the old cartridge
This link is for the BJC 4400, but I believe that the basic ink cartridge setup is the same....
Same printer different voltage requirements.....Start on page 64
http://gdlp01.c-wss.com/gds/5/0900007395/01/BJC4400_user_manual.pdf
Mar 01, 2011 | Canon BJC 4650 InkJet Printer
How do I change the ink cartridge?
The above has maintenance procedures for changing the ink jet cartridges and aligning them starting on P. 95.
Jan 08, 2011 | Lexmark X4650 InkJet Printer
How to reset lexmark c540 toner low?
Hi there
Open the ink cartridge door above the paper output tray on your Lexmark printer.
Push the release tab behind the ink cartridge to remove it. Pull the cartridge straight out of the ink compartment.
Pull the protective tape off the bottom of the new ink cartridge. Insert the new cartridge into the compartment and press it back until it locks into the compartment.
Close the ink cartridge door. Push the arrow button on the keypad to select either "Standard" or "High Yield" based on the type of cartridge you installed. Press "Select" when the proper type displays.
Sep 19, 2010 | Lexmark C540N PROD SPECS TBD Printer
Are the ink cartridges interchangable between the lexmark 4650 and the 4690? They certainly appear identical in every aspect.
Hello. The only common cartridge the X4650 and the X4690 uses is the #31 photo color print cartridge. Other cartridges for the printers are non-interchangeable. For your reference, you can click on this links to the Lexmark website. http://bit.ly/asi8dB and http://bit.ly/bvNeOa . First link shows you compatible cartridges for Lexmark X4650 and the second link is for Lexmark X4690. Hope this helps.
Mar 14, 2010 | Lexmark X4690 Wireless InkJet Printer
4650 printer. New printer. We keep getting
Check your color ink by dabbing on a damp paper towel, you should see 3 distinct lines, one for each color.If any color is weak or missing it will never pass alignment and you need a new cartridge.
Jan 29, 2010 | Lexmark X4650 InkJet Printer
How do you reset printer chip in lexmark ink cartirdge for X 4650 printer
open the lexmar productivity center
activate the wizard and click on "change printer cartridge"
take the printer catridge out and wait 15 seconds
reinsert the refilled cartridge
confirm change
when asked if the inserted catridge is new, answer "yes"
sorry, I translated this from german..
Oct 07, 2009 | Lexmark X4650 InkJet Printer
Where do you put the ink cartridges????? Can't see an obvious flap or space to put them!
You're in luck... Lexmark has the documentation available for download here: http://www.lexmark.com/publications/pdfs/2007/4650/en.html
See page 15.
If this solved your problem, would you kindly rate it as such?
Apr 29, 2009 | Lexmark X4650 InkJet Printer
Lexmark X4650 InkJet Printer Logo
133 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
