Question about LG RU-44SZ63D Television
Temperature too hot warning
I have an LG RU44SZ63D DLP TV. A few weeks ago I started getting a TEMPERATURE IS TOO HOT message displayed on my TV. I removed and replaced the bulb, cleaned all of the visible vents, and reset the bulb timer. I also moved the TV further from the wall to get better ventilation. The internal fans that I could see appear to be working. I am still getting still get the same warning message after about an hour or so of watching the TV. Do you have any other suggestions ?
    Top Expert:
  • LG Master
  • 74,999 Answers
Check the proper working of its cooling fans. . If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Jun 06, 2017
  • 3 Answers
SOURCE: Lamp timer
the password according to the lg service dept is 7777
Posted on Jan 01, 2009
  • 9 Answers
SOURCE: tv runs good for about 2 hours then gets error "
clean filters
Posted on Mar 11, 2009
  • 5 Answers
SOURCE: DVI warnings when you connect HDMI cables
Posted on Sep 22, 2009
SOURCE: lg tv problems ru44sz63d It turns on to a
Above are links for your service manual, and a training manual. This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
Posted on May 13, 2010
  • 679 Answers
SOURCE: I have the exact same issue as the unsolved
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
Posted on Feb 12, 2011
I have a 2008 Chevrolet Silverado and the warning lights keep coming on telling me AC not working/engine hot ,, ??
Cooling System Description and Operation
The instrument panel cluster (IPC) displays ENGINE COOLANT HOT message when the IPC receives a class 2 message from the powertrain control module (PCM) requesting illumination of this driver warning.
The IPC displays ENGINE OVERHEATED message when the IPC receives a class 2 message from the PCM requesting illumination of this driver warning.
DTC P1258: Engine Coolant Over temperature - Protection Mode Active
Have it check
Mar 03, 2017 | Chevrolet Cars & Trucks
Why does My Jeep run for about 200 yards then shuts down , after about 10 min. it will start and do the same .on the inst.panel it reads hot oil
You need to scan the engine control unit for fault codes, it will have some I am sure. Check The codes by turning the ignition key to run and then off, then to run and then off, then to run and wait for the codes to be displayed in the digital mileage display.
Oct 15, 2016 | 2010 Jeep Wrangler
01 Cadillac overheating and having no power like it has a governor on it
The engine is swelling because of the over heating. Stop using it !!!!!!!!! Gotta fix cooling system lest you seize the engine.
Nov 11, 2015 | Cadillac Cars & Trucks
Car won't up shift or down shift at hot temperature
your tranny shifts according to pressure the transmission control unit regulates the pressure to provide smooth shifts you need to take the car to a good tranny shop that has a scanner that can check the shift points
Mar 23, 2014 | 1996 Honda Civic
LG model LFX21960ST. No cooling in either fridge or freezer. The compressor comes on for about 7 seconds when first turned on and then will cycle on for a few seconds every few minutes. The fan in the...
There could be a loss of freon(unlikely but possible), the start capacitor for the compressor is bad (most likely) or the thermal cut off switch on the compressor is cycling from the hot compressor.
Mar 28, 2017 | LG Refrigerators
When I try to start the engine a hot message comes on at the temperature gage area, is this a sending unit default and it will be cleared by replacing the sending unit?
Does it continue to indicate "HOT" after it has started, or does it then go out? Does the vehicle also have a temperature gauge in addition to the over temperature warning light?
If the coolant level is at the correct level and the belt(s) are are correctly in place, it's most likely a bad sending unit.
Might try disconnecting the wire from the sending unit and see if this will cause the light to not come on.
Jan 30, 2011 | 1995 Oldsmobile Ninety Eight Regency
Savannah spas
probably a dirty filter!! take it out turn tub off to reset turn back on with filter out and c if nthis solves problem if so replace filter.
Nov 20, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
LG RU-44SZ63D Television Logo
95 people viewed this question
Computer Repairing
Computer Repairing
