Question about General Electric WCSR2090D Top Load Washer
Washing machine GE MODEL WCSR2090 Delay on Rinse/ Spin Cycle
When I wash a load using my GE MODEL WCSR2090 washing machine and it Hits the Rinse & Spin Cycle on the Start/ Stop Button, the machine itself delays, and there is a long dramatic delay and a humming sound before it catches( sounds like a clutch kicking in) before it actually clicks on.... then it finaly spinsto a stop... Worried about buring out the motor or something.. any ideas as to what might be broken and or how to fix it???
Thanks
djz83
  • 88 Answers
SOURCE: GE washing maching model #whdsr316g1ww
You should check how you have the washer draining if the hose is too low or connected directly to the plumbing it will give you the siphon problem that you are experiencing.
Posted on Jan 08, 2009
  • 56 Answers
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
Posted on May 31, 2009
SOURCE: no spin or agatae
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
Posted on Nov 03, 2009
jumptrout51
  • 3361 Answers
SOURCE: ge washer
Pull up sharply on the agitator to remove it from the shaft. Check the agitator mounting cup underneath it is probably stripped out. It is a replaceable part.
If the agitator is difficult to pull up,use a old strong leather belt under the agitator and pull it off using the belt.
Posted on Nov 08, 2009
SOURCE: I own a GE WBSR3140 Washer and I'm getting a
First of all, you do remove the a panel from the front.
On the inside floor of the machine, there were two "L" brackets with a hole for bolts, There were also two brackets on the bottom of the tub with similar holes. One pair was on the left bottom side and the other was on the bottom right.
It appeared that a bolt or some type of "dampening" connector was meant to go through to these holes. But there were no broken parts lying inside.That was my first "guess" for their purpose.
The left side (as facing the machine) "L" floor brackets and a tub bracket had been " bent" in such a way that that when the tub shook enough, the two brackets prevented the tub from moving too far. But not the pair on the right hand side. Go figure.
How it ever got this way or whether this was a "jury-rigged" solution at the factory (because they ran out of parts) is beyond me. Maybe the two brackets were meant to act as some form of "stop". But why were bent in such a fashion? And why only the ones on the left bottom side of the machine? I swear somebody bent them on purpose but that's me.
In any case, the tub had moved far enough that the bent tub bracket had slipped around the bent floor bracket. When ever the machine was on "wash" or "rinse" this "configuration" would bang against each other loudly. But it would not happen during the "spin" cycle.
I simply bent the two left hand side brackets back into a someone normal configuration (as with the bottom right floor and tub brackets) and put every thing back together. The banging sound was gone. However, you could still hear the brackets hitting each other on heavy loads. But it was not the "BOOM" I was getting before.
Eventually, the four rubber top corner "shock" springs will need replacing but at least things are quiet for the moment. But why or how the left bottom tob and floor brackets got so bent out of shape is beyond me. "Human intervention" or normal "wear and tear"?
Mark
Posted on Dec 22, 2009
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
I have a GE top load washer Model WJRR417G1WW did not spin out after rinse cycle.. any idea? Jen
heatman101
Apr 14, 2011 | GE Washing Machines
Water will not shut off in washing machine
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
May 28, 2009 | GE WBSR3140DW Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Dec 03, 2008 | GE WBSE2090A Top Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Apr 17, 2007 | GE WJSR2070B Top Load Washer
General Electric WCSR2090D Top Load Washer Logo
490 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
