Question about Daewoo DTQ-27S5FC 27" TV
TV DOES NOT COME ON VIA POWER OR REMOTE
DAEWOO TV DOES NOT COME ON
  • Daewoo Master
  • 5,568 Answers
The problem  may be limited to a blown fuse which may not be accessible from outside the set. Removing the back cover isn't normally a tough job and any fuse would be close to where the power comes in. I recommend pulling the AC plug overnight since there are components inside that can retain dangerous charges for hours. If it  is not defective (if clear glass, a flashlight will help seeing it), then the failure is probably in the power supply and this may require a professional to troubleshoot.
If you own a multimeter and want to try to locate the failure, post back to this thread and I will give you some guidance.
Posted on Apr 21, 2009
How do you change contrast on Daewoo DVQ 19H1FC TV?
Use the remote to go to the tv setup menu and change the contrast there.
Dec 21, 2013 | Daewoo DTQ-19V1FC 19" TV
My tv remote quit working. I would like the code for Daewoo TV, model No. DTQ-13P2FC to enter in another remote.
For Time Warner Cable TV Remote Codes for DAEWOO-TV's - Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html Then select TW Cable remote model. Under Control a Device -- first select type of device (TV) Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
Jun 21, 2011 | Daewoo DTQ-13P2FC 13" TV
Cant find code sheet need code for a deawoo tv for remote sru3006wm/17
Code Search Results--> --> Code For Model RCU300T
Code 004 for Daewoo TV Code 005 for Daewoo TV Code 006 for Daewoo TV Code 016 for Daewoo TV Code 017 for Daewoo TV Code 082 for Daewoo TV Code 171 for Daewoo TV Code 190 for Daewoo TV This is a basic set of codes for the TV, I am not sure of the model on the remote so I can only give you what I have. If these won't work, add a 1 in front of these 3 digit codes to make a 4 digit code, this should work. Good luck
Nov 15, 2010 | Universal Remote Control 6-Device...
DAEWOO TV
If youe tech inclined you can open the unit and see if the fuse is blown if you are uncomfertable on doing that then your going to need to take it into a repair shop.
Apr 21, 2009 | Daewoo DTQ-27S5FC 27" TV
Code for a tv remote
if u have a universal remote and none of the codes seem to work after trying all the codes and non still don t work follow these steps
1. make sure the power on the TV is turned on
2 press and hold code button until it flash twice
3 then press the TV mode button until the light flashes the press
4 power button until TV powers off
Feb 13, 2009 | Daewoo DTQ-20U4SC 20" TV
REMOTE FOR A TRUETECH TV?
Yes philips and samsung universal remotes can be used with truetech tv's. Trutech is a daewoo product so using a daewoo so try the daewoo codes and one should work for your tv.
Jan 01, 2009 | Universal Remote Control DIRECTV Universal...
Daewoo Universal Codes for Comcast Remote
For Daewoo TV Model DTQ-27U4SC, try this for Comcast Universal Remote (one with the red select button):
1. Press TV button
2. Press Setup button until TV button blinks twice
3. Enter 10451
4. Press Power button (TV should turn off and is set)
Mar 01, 2008 | Daewoo DTQ-1440FC 13" TV
Daewoo DTQ-27S5FC 27" TV Logo
209 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
