Not able to put big file on it like 4,7GB files..
I got Verbatim 250GB USB Portable Hard Drive 96532 and im wondering how i can put file on it i tryed put file of the size of 4,7 GB and it say the file is too large what i must do for this to work ?
  • 3 more comments
  • alexx_19_ Apr 21, 2009
    The drive is not full and where can i see where the drive formatted in what ?
    wow im so lost Device Manager and set the policy of the USB Stick device to "Optimize for Performance wha tis all that please ?
    This is not a dvd no just big file like games folder and all
    Thanx all got it now :)
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    First of all, what file format is the drive formatted in? and also is the drive full?
  • 4,806 Answers
Hi there.
Click on computer/my computer, find your external drive, right click on it and choose properties, you will get a new window, in the general tad look for where it says file system, if its says FAT or FAT32 then it can't take a file of that size so it has to be reformatted in NTFS.
If you need any help on how to do this post back.
Good luck
Posted on Apr 21, 2009
  • 123 Answers
Make sure its formatted in NTFS format, FAT32 can only handle files upto 2GB
To be able to formt it to NTFS you have to go to Device Manager and set the policy of the USB Stick device to "Optimize for Performance". The default is to optimize for Quick Removal, which restricts you to the FAT filesystem
  • Fritzelly Apr 21, 2009
    Also make sure you use the disconnect media before unplugging it as you may lose data if you dont since you've not disabled the quick removal option.
    Unless you specifically set it to NTFS it will be FAT32
    Goto Start/Control Panel, select Device Manager
    Make sure the usb is plugged in
    Under Disk Drives you will see the drive along with any other hard drives
    Right click the usb drive and select properties
    Click the Policies tab
    Select Optimize for permformance and click ok
    You can now format to NTFS
  • Computers & ... Master
  • 5,660 Answers
Perhaps, break the file down into two or three parts. Put the files in a folder.
4.7GB sounds like a DVD video. Compress this file down.
http://www.thefreecountry.com/utilities/dvdcdburning.shtml
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
File too big for my verbatim hdd
While you can either try compressing the file and it might fit on.
Make the file smaller.
Delete what you no longer need.
Or get a bigger hard drive.
Feb 04, 2012 | Verbatim 320GB USB Portable Hard Drive
I have a dell pc, every time i drag a movie file to the portable drive, it says "Cannot find specified file. Make sure you specify the correct path and file name." What am i suppose to do??
Make sure you are not dragging a "short-cut" file - this is not the actual file. Locate the actual file and try that - verify it's the actual file by reading the properties extension such as ".mpg".
Dec 29, 2010 | Verbatim CLON Portable, 250GB, USB,...
Verbatim hard disk250gb(model#47562) pleas give me softwear
I formatted my drive on windows 7 and it went from fat32 to ntfs and i want it back to fat32, how do i do that. it says that the volume is to big?
May 21, 2010 | Verbatim SmartDisk Firelite Portable USB...
I am format my hard disk{verbatim 250gb model #47562)now he not support with my dvd player. there showing file not available. so i need softwear
it is not a sofware problem... if the disk was recognized before.
try reformatting the disk and select fat32 as file system. do not chose quick format.
try again to connect to dvd player.
regards,
paolo.
I am formate my hard disc 250gb. now he not
If you format your Hard Disk then all files will be deleted thats why if you insert your Hard disk to DVD player then it will show that the file is not available.
thanks
I have a Verbatim 250USB drive and have never had a problem with it until I attempted to copy some HD movie files to it from my computer's hard drive. I am attempting to copy .mkv movie files to the...
firs:
try to format your hard drive, then try again.
if you still cannot do it, do a low level format, using this tool:
http://hddguru.com/software/2006.04.12-HDD-Low-Level-Format-Tool/
if you still cannotdo it, it may be a harware problem. try to copy a big .mkv file like that from another pc, to be sure it isn't your pc's fault, if you can do it, then it's your pc, if you still cannot it's the disk.
in the firs case the troublesooting is quite difficoult but if you post your system configuration i may help.
in the second case if allso a low level format fails, then i don' think we can do something for youo... you should get assistance from the manufacturer....
hope this help,
Paolo.
May 19, 2010 | Verbatim SmartDisk Firelite Portable USB...
The smartdisk 250gb external hard drive is dead
You could always remove the drive and hook it up to another computer .
That would confirm if it is either the enclosure or the drive.
If another computer can read the drive directly then your files are safe.
If not then chances are you have lost them.
Aug 13, 2009 | Verbatim SmartDisk Firelite Portable USB...
When I plug my portable hard drive into my computer it flashes
i speak only a little english. my problem is the next : i can´t see the portable hard drive in my pc ( windows xp ) . i would like to know the answer to this problem. thank you
Nov 18, 2008 | Verbatim SmartDisk Firelite Portable USB...
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
