Question about Brother MFC-8440 All-In-One Laser Printer
The printer says there is a paper jam. I have
The printer says there is a paper jam. I have removed all paper, rotated every knob and opened every oraface of this printer. There is nooooo paper jam. What do I do?
I can only tell you that, after,trying all the other solutions, I got one of my husband's white handkerchiefs and a bottle of rubbing alcohol. I unplugged the machine and cleaned every roller I could find, including the paper tray, the back, the front, and on the drum. Magic--it's fixed.
Posted on Mar 25, 2011
I have MFC 8440, every time I print our copy the paper is jamming, it is jamming in the cartrige
Posted on Sep 11, 2009
Hi, i had the same problem, I tried both resolutions above, but neither worked. Then I took out the toner cartridge, and whala! There was the the culprit. Problem solved.
Posted on Aug 14, 2009
I had a paper jam. I followed the instructions in the manual and removed the jammed paper. Afterwards the "Paper Jam" alert still remained on the display and I was not able to print. I turned the unit off for 15 minutes. I powered it back on and the "Paper Jam" alert went away and unit is working again. Hope this works for you as well!
Posted on Jul 19, 2009
Try adjusting your paper tray. If you have the tray that adjusts from legal to letter it sometimes gets wiggled to some place inbetween. Just push it back into the letter position.
Posted on Jun 15, 2009
Misfeed in the in the automatic duplexer
open automatic duplexer door you will see 4 parts to open and green ring for rotating. rotate it the jam paper it will removed. or open all 4 parts you will see the paper if not open drower and remove the paper jam,
Jul 29, 2010 | Toshiba E-Studio 3511 Color Copier
Paper jam
you need to remove the jammed paper, you may need to take the printer apart as much as possible to get it all out, the manual generally has instructions on clearing a jam do you have the manual do you need it?
Oct 20, 2008 | HP Photosmart 3310 Printer
Paper jam errror in canon ip2680 printer
Paper jams are quite a common problem faced by printer users.
Shutting off the printer and later restarting it can also cause the cartridge to move thus resulting in the tearing of your paper. Hence it is highly recommended that, in case of a paper jam, you leave your printer and computer on.
To remove a paper that's jammed, simply turn your printer around and look for the rear access door. This is mostly covered by a longish, horizontal flap that can be flipped open. You will find the jammed paper the moment you open the door. Some legacy printers have a rotating knob that turns the rollers so as to remove the jammed paper to the rear. This looks quite similar to the knob you find on a typewriter. However, newer printers don't have such knobs anymore. You will find the jammed paper placed in the back of the printer. Gently pull it out without affecting the rollers or touching any of the internal machinery. Avoid pulling the paper out with too much force. The paper should smoothly slide out. If it doesn't or if it is torn in many smaller parts then it means that the paper has been crushed. If this is the case then use a brush to gently move the paper that's caught in the rollers. The brush can also be used to clear away the smaller scraps of paper that are scattered in the innards of the printer. Make sure that you avoid touching the roller and the inner components while doing so.
Apr 14, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Approx. one third of A4 sheet jammed but can't be seen
Hi:
Your printer has a rear access door which can be removed by a rotating knob that is recessed . Rotate the knob counter clockwise, and the rear access door will pull out. You should then be able to get at the jammed paper. Reinstall the the access door and you should be good to go.
Mar 17, 2010 | HP DeskJet 960c InkJet Printer
How can i remove the paper inside the printer
For the paper jam issue turn around the printer and open the back door to pull the paper.
and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
When we put paper in the printer it goes cricked
Lexmark printer have paper roller problem take printer for once service
Jul 25, 2009 | Lexmark X1270 All-In-One InkJet Printer
Paper Jam - HP G85 Ink Jet Printer
You open the door from the back of the printer (turn the knobs) and the paper can be removed from the back. After removing paper jam, replace the door. It is a long door as wide and the printer, but about 2 1/2" wide.
Feb 28, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
My cannon super 63 image runner 1370f
look on the control panel if there is a diagram of your printer it will usually light up the area where the paper jam is located.
once you find location of paper jam there is normally a green knob in the area of jam that when you manually rotate it will release paper also open paper drawer check for jam or unplug and plug copier back in somtimes this will force paper out as it resets
Jan 13, 2008 | Canon IMAGERUNNER 6570 Copier
Paper Jam
I have exactly the same printer, here's how to remove jammed paper.
1. Unplug printer from mains and your computer. 2. Turn Printer around 3. There is a darker-grey panel with a knob in the middle of it. Turn the knob anti-clockwise to release the panel 4. The jammed paper should loop around the roller. Gently pull on the loop slowly until it has released fully. 5. Put the panel back on the printer and turn knob anti-clockwise to lock it into place.
Hope this helps.
BurntLime
Oct 29, 2007 | HP DeskJet 960c InkJet Printer
Brother MFC-8440 All-In-One Laser Printer Logo
552 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
