Question about Whirlpool Washing Machines
Whirlpool washer duet ghw9100lq1
Washer fills with water in the off mode. will a water inlel valve fix this?
  • 6,784 Answers
Hi. this issue is being caused by a defective flow meter. this is part of the water valve assembly but, its not integrate and it can be replaced separately without replacing the entire water valve device.
Simply replacing the flow meter will fix this issue. I have posted a link below that will allow you to purchase this part online.
CLICK HERE FOR YOUR REPLACEMENT PART.
Please rate and god bless:)
Posted on Apr 21, 2009
  • Michael Masters
    Michael Masters Apr 21, 2009
    Hi again. After further research, i recommend replacing the water valve as well. This is great preventive maintenance and its always a good rule of thumb when replacing one conjoining part, its best to replace the other connecting assembly as well.
    CLICK HERE FOR YOUR WATER VALVE ASSEMBLY.
  • Michael Masters
    In conclusion, you will need to replace the water valve and the flow meter as well. This will fix your unregulated water flow issue in a whole.
Code f 20 what does that mean and how can I fix it.
A possible solution to an f 20 fill error for a whirlpool duet washing machine. Blow out the pressure hose that connects to the pressure switch.
Before doing any of these fixes first ask yourself if you have over loaded the machine. Too many Bulky - heavy items will cause this same message.
How to fix Whirlpool Duet F20 Error:
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load duet washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.zTyr5Yy1.dpuf
Oct 16, 2014 | Whirlpool duet Washing Machines
Water drains back through the fill lines.
THE COLD AND HOT WATER CANT GO BACK IN TO THE WATER VALVE ! NOW IF THE DRAIN WATER COMES BACK IN AFTER DRAIN MODE LEFT DRAIN HOSE UP A FOOT TALLER THIN THE WASHER OR CLEAN YOUR PUMP THIRS A CAP ON THE PUMP YOU CAN REMOVE TO CLEAN . NOW IF THE WASHE IS FILLING UP WITH WATER WHEN ITS OFF THE WATER VALVE IS BAD
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet fills when off
It's Quite easy.
To test Inlet valve, follow the below guide :-
http://www.acmehowto.com/howto/appliance/washer/check/inletvalve.php
To test the Water level switch/Pressure switch, follow the below guide :-
http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water keeps filling even when washer is off
if it still flows with the unit unplugged then replace the cold side inlet valve for the fix , it my be called the mixing valve on a part search. Phil
Jun 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When washer was off it filled up with water and overflowed will a water inlet valve fix this. this is a whilpool washer frontload ghw9100lq1
Yes, it should. The only way water can enter a washer when off, is through a stuck inlet valve, or by siphoning water from a drain hose installed too deeply in the stand pipe. If your machine had enough water coming in to overflow, that definitely sounds like a bad inlet valve.
Apr 21, 2009 | Whirlpool Washing Machines
My Whirlpool Duet Washer fills up 1/4 of the tub on its own.
Sounds like a defective fill valve leaking water in although the machine is off.
First turn off your water and remove the hoses. Clean the screens in the hoses and the fill valve.
If that does not correct the problem replace the fill valve.
Feb 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader
Washer should fill, remove hoses, check screens in hoses and or valves on machine for clogs. Verify water valves at the source are turned on. If all this checks, you need new valve installed on your washer.
May 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
139 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
