Question about McCulloch Garden
Petrol hedge cutters wont start
I have a set of McCulloch gladiator 550 petrol hedge cutters but for some reason can't get then to start. They cut out on me one day and i have never been able to get them started since. I have check to make sure the fuel is going through the cab and to make sure there is a spark from the spark plug but this is all i know to check does anyone else have any idea to help me out would like to say thanks in advance for any replies.
Cheers Graeme
4 Suggested Answers
  • 183 Answers
SOURCE: mc cullock electrolux gladiator 550
if using sthil oil its 50:1
Posted on Jul 31, 2010
rycgl
  • 1545 Answers
SOURCE: need to know fuel mix for mcCulloch gladiator 550
I don't know the age of this machine, but more and more of the newer units are using a 50:1 mix to satisfy the newest EPA emissions regulations. I suggest using a synthetic or synthetic blend of 2 stroke oil. ....the big box stores sell the oil...Echo one of the best. I would use synthetic and mix it 40:1. Here is a fuel mix chart to show you how many ounces of oil in a gallon of gas that is. If you make a 1/2 gallon batch of fuel mix, just use half of the listed oil amount for the mix.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
40:1 is 3.2 ounces of oil in a gallon of gas...or 1.6 ounces of oil in a half-gallon of gas
Posted on Jul 04, 2011
  • 6 Answers
SOURCE: how do you remove the drive gear from a McCulloch
I have just spent a couple of hours on this.
You obviously have to dismantle the thing and get the plastic chassis off the engine so you can get at both sides of the gear.
The clutch has a bolt through it that threads into the gear. It's about 1 inch long. There are two holes in the clutch one of which you can line up with the bearing retaining screw hole. There is a small flat on the end of the gear you can put an open-ended spanner on to unscrew it. It is a normal thread.
Okay in theory.
I broke the flat off the end of the gear using mole grips. I did not know what I was doing anyway because there are no success stories that I could find on the internet.
As I was not sure how it was put together, if it was pressed on or threaded on, and which direction the thread went, I ground the end of the gear down with a 4 1/2" angle grinder and only did a small amount of superficial damage to the rest of the chassis, then knocked it through the bearing and then found out that it unscrews!
If you have to resort to this, I tapped the clutch down using a large socket (and a hammer) until it was tight against the casting and then turned it over and knocked the bearing (with the aid of a suitably sized socket) back to expose a small amount of the shaft so I could grind all the teeth off and not leave a shoulder. I also tapered it which made it easier once it started to move.
I hope this helps!
Posted on Oct 15, 2011
Mcculloch petrol strimmer
Agnes take of the cutting head again and see if it runs at full speed without it. If it does you have either put the head on too tight or it's the wrong head.
May 11, 2014 | Garden
Mcculloch gladiator 550 hedge trimmer
how long ??? suspect carb adjustments or plugged exhaust ...
Dec 05, 2013 | Garden
Need to know fuel mix for mcCulloch gladiator 550 petrol hedge trimmer
Jul 04, 2011 | McCulloch Garden
Mcculloch hedge cutter..... Ratio of oil to petrol please ? 4 litre tank
Hi Guest,
The ratio is the same no matter the tank size or unit of measure.
40:1 petrol to oil
Best regards
Host
Jun 28, 2010 | Garden
Mcculloch Virginia hedge cutter manual
mcculloch virginia mh542 hedge trimmer, fires 1st time, will only tick over roughly on full choke only then stalls when throttle applied, I have fitted new plug'cleaned air filter and new fuel mix but no change.
Nov 25, 2009 | Garden
What ratio of oil do you reccomend for the
Depending on the age of the McCulloch cutter it could be 25:1 32:1 or on rare occasions 50:1.
Regardless you can't go wrong with 32:1. This ratio can be used in ANY 2 cycle engine with great results.
Jun 23, 2009 | Garden
Garden Logo
439 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
