DEAD AC COMPRESSOR
AC COMPRESOR WANT WORK .HOW DO I REPLACED IT ?
  • 8,220 Answers
Remove and save the freon gas using a recovery machine. Use a torch to remove the high and low side tubing from the old compressor. remove the old compressor ans connect another in its place. Install a new filter drier. Remove the air from the system with a vacuum pump and and recharge the system using guages and new freon. Fairly simple but as you can see a lot of specialty equipment is needed. You cannot buy the freon without a card, and noboody in the business is going to be willing to sell you a compressor if you are not in the business.
Posted on Apr 21, 2009
AC compresor won't star
TAKE THE CAR FOR A TEST DRIVE WITH AC ON.IF U STILL DONT GET COLD AIR U MIGHT NEED TO REPLACE THE COMPRESSOR!!CHECK WITH THE DEALERSHIP IF U HAVE A GOOD WILL WARRANTY!!!!!!!!!!!!IF U DO THEY CAN REPLACE THE COMPRESSOR SAFELY!!LET ME KNOW!!
Mar 22, 2014 | 2010 Volkswagen Jetta
Ac problem
jump the low or high pressure switchs this switchs are located on the a/c lines of tje compresor not run check power to the compresor if you have power maybe the compressor is gone check the a/c control pannel to and take a second opinion before expend money
Aug 04, 2012 | 2006 Kia Sedona
Repleace ac compresor for ml 320 99 year
evacuate the system,remove a/c lines from compressor,remove belt,then 3 bolts,2on the body of compressor and one on the back. thats simple.
Jun 27, 2012 | 2001 Mercedes-Benz M-Class
Installing compressor 91 civic do the lines have o rings or gaske
this honda uses o rings, these orings should come with the compresor,also you should replace the filter dryer when replacing the compressor,if the compresor locked up you may want to flush the system to get any metal chips out or it will destroy the new one, heres a picture of the filter dryer, its located next to radiator in engine area, good luck,881d179.jpg
Apr 28, 2010 | 1991 Honda Civic
Ruud 10 compressor not working
First make sure there's power to the unit outside , if yes set the theermostat on cold ,auto and to the lowest degrees ,then look the outside unit contactor, it should be pulled in (sometimes it takes to 5 minutes beacause a time delay) , if not the problem is in the thermostat , but if yes and there's power on the other side of the contactor ,either the compresor running capacitor is bad or the compresor itself went bad .Try replacing the capacitor first (the cheaper option) and adding a startting booster in paralel with the capacitor ,if still the compresor doesn't start you nedd to replaced it.All this counting that the fan in the outside unit works ,if doesn't replaced it.
Aug 05, 2009 | Ruud Matching Split Air Conditioner
Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Jul 31, 2009 | Freezers
Compressor not cycling on and off
unless the compresor is on u cant get a good eye on if ther is enough freon but still should cycle on and off/if it has a low side cut out switch (scews in the large line with two wires)that can be checked by bypassing the switch/but mind u it could still have a problem with ac system/and if the ac works when bypassed(very short run time)then replace switch with new one right away,also look for ac clutch relay and check or replace
Jun 30, 2009 | 2002 Dodge Durango
Ac compresor clutch
this isn't easy and you will need special tools.  You will most likely need to have the compressor on a work bench.
Mar 15, 2009 | 2004 Ford Taurus
AC dask board signal
Replace the A/C compressor revolution sensor, bolted to the side of the compressor, unless the connector was inadvertantly left unconnected. This is the only reason the AC light will blink.
Aug 31, 2008 | 1995 Toyota Tercel
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
