Question about Ovens
I have a whirlpool polara oven that kicks whenever
I have a whirlpool polara oven that kicks off whenever it gets hot error code e4 f3, i have found this is the error code for the bottom oven sensor;? Does this mean I should replace it, can I do it myself and how?
    Problem Solver:
  • 8 Answers
You can google sears appliance parts and order it from them I found them to be the cheapest for parts .they come out of canada. The error codes are mostly right and you probaly can do it yourself.
Posted on Apr 21, 2009
Door latch stuck
This error means your temperature sensor (probe) has failed and needs to be replaced.
Nov 05, 2014 | Whirlpool GMC305PD Electric Single Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
Fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Sep 07, 2012 | Whirlpool Ovens
I have a whirlpool accubake gas oven model sf387lekqo and I keep getting a e4-f3 code which says I have a bad sensor ,I have tested them as shown and they and the wiring check out good what else could it...
I just want firstly to assure that you have checked the oven sensor,you same them which to me means more than 1 and one that model their is only 1 oven so only 1 sensor and your checked it and found that at room tempature it had 1060-1100 ohms resistiance?
Aug 22, 2011 | Whirlpool Ovens
I keep getting an error code ED-F3
The F3 - E0 means Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes.
Nov 26, 2010 | Whirlpool Ovens
Oven control lock beeping along with F3:E4 flashing on the display
Hi-- The code described; F3 E4  indicates an open circuit- oven sensor.  As far as oven problems go this one is easy to fix. -------Unplug sensor and check resistance. Normal is around 1100ohms. ---If open, then replace with new part.  <This will solve the problem>.  You did not provide any other information besides 'beeping' and 'F3:E4'.  A simple Model # from the tag on unit is required for any service or information.  However, since this is a specific fault code, the oven temperature sensor is the most likely suspect. Please acknowledge this post. Solution is to replace the oven temperature sensor.  Thanks-  Ed
Mar 30, 2010 | KitchenAid Ovens
Oven turning off
F3 - E4 Oven temperature sensor (RTD) opened (lower oven, if double oven). You will have to replace this failed sensor to restore normal operations. If your oven is a double version, it will be located in the lower part. If its a single range, it will be located in the oven compartment. The Oven Temperature Sensor has failed.
Please rate and god bless:)
Apr 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Error code F03
although i don tknow what model your talking about all the F3 codes in ovens is pointing toward bad oven sensor, replace oven sensor
Mar 16, 2008 | Ovens
Ovens Logo
562 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
