My pc does not support windows xp sp3
My harddisk is making some harddisk is seagate sata type of this is a problem. bcoz i bought my pc last year.
  • 150 Answers
What type of sound is the hard drive making? Clicking, grinding, loud whine's? Typically this is a sign that the hard drive is on it's way out, I've personally had bad expirence with seagate drives and I try to avoid there products. I would suggest backing that drive up to an external drive while you can, eventually that drive will die and need to be replaced, so back it up while you still can. I recommend Maxtor, or western digital drives, I've had great luck with those. Good Luck Hope this helps
Posted on Sep 22, 2007
  • 113 Answers
First contact your retailer or distributer and find out about your warranty etc. then open the case and just check that the power, SATA and screws/clips are secure. then backup your personal files profile. if you are running vista, or XP type: migwiz into the run box in your start menu and save the files into a USB or data disk. just encase there is a hardware error.
Hello, my main board is asus p4p800-vm running xp home with sp3 upgrade with ide hdd's and is running well. i bought 2 new sata hdd's because the board has 2 sata ports, i set the bios to auto to see the...
Windows will not see them because you need to download the SATA drivers for the motherboard from the Asus site.
Download and install to a floppy or USB (advise the latter)
Install windows,and you will get a "press f6 if you want to install a raid device ..."
Press F6 and hopefully, windows will find the drivers, highlight the ones it wants.. the rest should be simple
Jan 06, 2011 | ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/...
How do I add a second HD
Turn the machine off
Open the case
Look to see if there are IDE connector (Wide Flat cable with a connector usually grey)
If this is not present look for a SATA connector usually a small red or blue wire similar to a cat5e network cable
Scew your HDD in place in the rack connect the cable either IDE or SATA
If you have an IDE drive look for a 4 pin female connector from the power supply
If you have a SATA drive look for the connector from the power supply
Once all is connected then reboot you computer typically your bios should auto detect it.
Let me know what happens from here
Sep 19, 2009 | Dell Precision T3400 375W 32bit Computer...
My 250GB HD250HJ SATA has stopped booting with my other 160gb seagate,i have xp sp3 with amd 4600+,while booting eindows diskcheck starts and finishes after about 1 hour,onnce done it just stays that...
It sounds like your hard drive is messed up. Don't worry you can have the data retrieved from your hard drive by using this online company that I highly recommend:
Aug 31, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Im using hp dv6700t laptop,i want to install xp on my laptop
Your laptop has a SATA hard drive and windows XP doesn't recognize those drives cause the operating system came out before those drive were made.
Follow these steps I found thru google to get windows xp sp3 to recognize your drive:
You'll have to use a program to do this but people explain how to do it on that page plus the program is free.
Jun 25, 2009 | HP Pavilion dv6000t 15.4" Notebook Laptop...
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
I m not able to install win xp sp2 on my compaq notebook
windows xp cant detect ur hdd bcoz its SATA hdd.
1. Install vista instead of XP
2. You need to disable this SATA feature in BIOS to install OS.
SATA disable steps.
1. Restart the computer and start tapping F10 key.
2. Choose System Configuration tab.
3. Disable SATA native support.
4. Save and Exit the BIOS by pressing F10 key
Aug 21, 2008 | HP Compaq Presario V5000Z Notebook
Problems Installing my 160 GB Seagate SATA HDD
you need to go in bios and set sata to legacy for no F6 driver. if its on native it need a driver from floppy on xp cd boot . if its not detected in windowws as a slave. u need to run diskmgmt.msc and fin the unalocated drive and create part then format it ntfs
Nov 05, 2007 | Asrock K8Upgrade-VM800 Motherboard
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
