Question about ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095)
No beeps, No image
Hi guys, I have the following problem. When I start my PC, I have no beeps, nothing. Also, my Dell screen mentions that it does not receive any signal from the computer, but it does recognize a DVI connection. The video card seems to work fine, and the MB is brand new. I was thinking about a problem with the USB ports since the Dell screen needs 1 DVI connection and 1 USB connection. But, still it does not explain the "no beeps" situation. Is it possible that the CPU is damaged? I have been through many "by the book" re installation process and I still can't find anything wrong. So far: - I switched the MB speaker to another computer and it works fine. I used another computer's speaker, and received no beeps. So it rules out a faulty speaker. - For the Dell screen I tried the S-Video connection and still I get the same message. The Dell screen works fine with another PC, so I guess it rules out a faulty USB cable. here is the computer parts : Zalman ZM-600 HP Power supply (600w) AMD Athlon 64 X2 MB Asus M2N32 SLI Deluxe EVGA GeForce 8800 GTS 640MB 2Gb Corsair DDR2 6400 C4 Seagate Barracuda 7200_10 (320Gb) Thanks for any help
Make sure that you have the 12v cable from your power supply hooked into the 4 pin port on your motherboard, this is most likely your problem. It should look like the (crappy) picture of the port below.
Posted on Feb 20, 2008
The Bios is old for the processor, i solved this problem with new version (with old cpu) and OK
Posted on Feb 10, 2008
I have the same problem and my problem is Mother Board. Unfortunatly, My mother is the same and I already have the same problem before.
Try to check your MotherBoard.
Posted on Dec 26, 2007
Also if you have two different types of RAM installed it will stay blank... Check the RAM slots and make sure there the same type of ram sticks in eachmodule( I had the same issue I had ddr2 500 in one and 800 in the other).
Posted on Oct 03, 2007
    Problem Solver:
  • 8 Answers
1st,try inserting other memory module...if you still get nothing, there is only 2 major problem there.it may be your processor since amd's are heat sensitive or its your motherboard that's faulty...most commonly the BIOS may be corrupt.
Posted on Sep 22, 2007
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
My Dell dimension 9200 doesn't start up anymore. It worked perfectly, went in stand by mode and I could not revive it anymore. When I start it, the fan works, the control lights flikker and go out again...
Hi it sounds like a RAM problem. i recommend you reseat the Memory sticks inside of the computer or you can follow this link directly from dell on how to isoltae the problem based on beep codes that you are getting.thanks
http://support.dell.com/support/edocs/systems/dim9200/en/SM_EN/adtshoot.htm#wp1054146
Jan 11, 2011 | Dell Dimension 9200 PC Desktop
I turn on my computer and i get a dell start up screen. and in the bottom right hand corner it says press f2 for setup or f12 for boot options.. then it goes to a black screen that says "media test...
Hi. Try these simple steps: Restart your computer and press F8 when you see the Dell Screen. In the advanced Windows Option, choose Last Know-Good Configuration and press Enter. If nothing happens and you didn't boot to windows, you may need to reset the system back to factory image.
To do that, Do the first 2 steps if you're using Vista. If you're using Windows XP, on the Dell logo, Press Ctrl+F11 to boot from the recovery partition. Follow the instructions to recover system back to factory image.
Hope it helps!
^_^
May 16, 2010 | Dell Inspiron Mini 10 Notebook
PC will not start
This sounds like a memory error, can you define the beeps. There is a thing called a "beep code" on all motherboards, the website for the motherboard defines what the beeps mean. For example: one long beep followed by two short beeps of continous spaced beeps without a break. chris http://www.motherboardsrus.net
Jun 06, 2009 | Dell Precision Workstation 670 PC Desktop
Code (Vclr) on screen and one beep then two beeps twice.
Your memory modules are faulty (or dirty). Try them one by one and clean the both the modules and slots with alcohol (or Contact Cleaner).
May 17, 2009 | Dell OptiPlex GX240 PC Desktop
Dell Demision 8200 just beep
Kindly follow the troubleshooting steps on the following steps
http://tinyurl.com/dgb5x5
Chances are that you have a loose memory modules
Thanks
Proton
Mar 12, 2009 | Dell Dimension 8200 PC Desktop
My dell dimension 2400 beeps morse code like and won't load
you have to follow the beeps very well to understand wat is the problem, each type of beep gives you sign for problem. so check if its one beep, two, or three, short or long, this makes very easy to you to define the problem.
Try to take out that parallel port if your pc works fine, this means this connector was not compitable to your board.
Best regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Feb 28, 2009 | Dell Dimension 2400 PC Desktop
6 beeps at start up
Sounds like a processor or cpu failure.
Beep Codes
Please vote if you found this information useful.
Thank You
Apr 18, 2008 | Dell Dimension 4300 PC Desktop
ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095) Logo
370 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
