I want to change the optical drive
How do I remove the optical drive from a winbook x540 laptop?
Look directly below the optical drive there will be a sliding switch slide it and remove any near by screws attached to the dvd drive and then slowly pull out the drive.
that's it you get your drive out
Posted on Apr 22, 2009
Winbook tw802. How do I hard reset?
    1)Begin by holding down power key to turn the device back on.
    2)In the next step open main menu
    3)Then from the screen in front of you find and select settings
    4)Then tap change PC settings and choose update and recovery
    5)In this step select recovery
    6)Afterwards search and choose option remove everything and reinstall windows
    7)When the appropriate information pop-up comes up tap next to begin the process
    8)Success! After about 30 minutes your tablet is ready to use
http://www.hardreset.info/devices/winbook/winbook-tw800
Dec 19, 2015 | Computers & Internet
Replacing dvd drive
Most times there are a few screws just below the drive. Open the drive, remove the screws, the drive should slide out. It'll be a little stiff at first until it's unplugged.
Oct 22, 2012 | Micro Electronics WinBook Si Notebook
How do I remove a cd-rom from a hp dv5
1) Work on a table.
2) Remove ALL power to the laptop. AC adapter (Charger) and Battery.
3) Turn the laptop over Front facing you. There is one single Philips head screw to remove.
It's on the bottom of the laptop towards the Front, and is just past the Microphone, and Headphone jacks.
4) Screw removed use a paper clip to open the optical drive tray.
The paper clip is straightened out, then a third of it is bent into a handle to hang onto.
Looking at the optical drive with the laptop upside down, there is a small hole to the Left, on the optical drive tray. Insert the paper clip tool you just made into the hole.
This is a manual release to open the optical drive tray.
Hold onto the optical drive tray with your fingers, pull the optical drive out.
If you are going to replace the optical drive, be sure to remove the optical drive bracket from the back of the optical drive. (Two Philips screws) Install the bracket on the new optical drive.
Regards,
joecoolvette
Nov 15, 2010 | Computers & Internet
Where is the WiFi hardware switch on my WinBook, model MS-16372 laptop?
normally the switch is along the number keys 1 to 9 is a wireless cymbal , you must press a key with this key most of tmies its the fn key , not to sure about the winbooks, hope this helps
Nov 29, 2009 | Winbook Corporation X 510 (618996143061)...
My winbook wont charge
turn off remove the battery
plug in charger and see if laptop turns on
fiddle with cord to see if laptop cuts off. If so you need a new charger or
the jack in the laptop has a short.
If if stays on the battery may be bad
Nov 08, 2009 | Micro Electronics WinBook Si Notebook
My winbook 330 will not turn on. I have the power
You could try removing all memory, CMOS battery and try to clear BIOS by holding down power button for 30 seconds.
Re-install all and try to restart.
Sound like unit may have run hot and burnt the Processor.
Sep 03, 2009 | Computers & Internet
Laptop CMOS battery
This is for Winbook WinBest 233MMX may be good for other Winbooks
Had trouble booting then just quit booting altogether...
For a quick fix that won't require soldering....
Replace the cmos battery2.gif. If it is more than 7 years old, it will most likely be weak or dead.
Remove the keyboard by sliding the KB toward you and lift the top up and slide out, Remove KB ribbon cable2.gif from connector by pulling on the plastic tab, remove the 4pin KB power connector. Then remove bottom screws and separate the case.
Locate the 3V battery, Pry the top tab of the 3v battery off the welded ends with a small needlenose, Pry the battery off the mini board, bend battery tabs so the new non-tabbed battery will be squeezing the new battery for contact, + is up!, add a piece of electrical tape to secure it from sliding. Replace bottom case and screws and then re-attach keyboard2.gif ribbon cable and 4 wire power connector. Re-boot and reset cmos ( CTRL-ALT-S ) on boot. Set your time. You must set the boot sequence to C:. It will then auto boot to C: WALLA! WIN98!
Mar 18, 2009 | Micro Electronics WinBook J1 Notebook
Need drivers for a winbook laptop
Hi there
Get the XP drivers here:
http://pcsupport.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=pcsupport&cdn=compute&tm=16&f=00&su=p284.9.336.ip_p504.1.336.ip_&tt=11&bt=1&bts=1&zu=http%3A//www.winbookcorp.com/
Thanks for using Fixya!!!
Feb 01, 2009 | Winbook Corporation WinBook A710...
Computers & Internet Logo
David Payne
David Payne
