Question about Hotpoint WMA64 Front Load Washer
Door wont lock
The washing machine stopped after about ten minutes of the wash and the light for the door started flashing. Now the door wont lock and the wash will not start.
  • 1 more comment
  • guest 1 Sep 24, 2007
    thanks
  • Anonymous Mar 23, 2014
    Kenmore washer 110226002010 lid lock flashes and then shuts off and wash machine wont start
  • Anonymous Mar 24, 2014
    lock ligt flashhes door suts but wasing wont start unless bang machine
Wma62p,the door wont close it springs open,has the catch gone please,and how much is a new catch,and can i put it on.corinne
Posted on Mar 19, 2011
    Novelist:
    Champion:
  • 244 Answers
To test if there is a fault on your interlock you can close the door now with your hand bang it on the front of the washer were the door hits the catch most cases if it faulty than the washer will start it will then need replacing only thing you can do if faulty m8
Posted on Sep 24, 2007
  • mccsvaleter Jul 04, 2011
    done all that and replaced lock switch but still the same !
  • Cielito Camba Oct 08, 2013
    still the same with me. have you found a solution mccsvaleter?
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
May 03, 2014 | Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Wash cycle starts then stops and door lock light flashes.
Turn it off and wait 5 minutes. The light will go out and the door will release.
Feb 22, 2013 | Washing Machines
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 18, 2011 | Washing Machines
My washing machine wont start. The door lock
You will have to replace the door lock wax motor.
May 21, 2010 | Hotpoint Aquarius WF220 Front Load Washer
My washing machine wont work properly!!!!!
may i suggest that you check that the filter is not blocked, i had a very similar problem to this except my machine stopped washing and started making a beeping noise.hope this helps
Aug 03, 2008 | Washing Machines
Problem with washing machine
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
Oct 23, 2006 | Zanussi FLE1416W Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
436 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
