Question about Refrigerators
Water leaking out from the bottom of freezer door.
WAter is leaking from the bottom of the freezer door. Should I take the door apart to look for the leak?
  • rodger599 Apr 21, 2009
    Thanks for the response. We just purchased this refrigerator used and it had not been in use for awhile so there was not condensation buildup on the door. It has the water and ice in the door and the water tube enters the bottom corner of the door and runs up to the dispenser. Water is dripping from the bottom side of the door when I turn the water on . It stops dripping when the water is off. My concern about taking the door panel off is getting it back together so it seals properly. Is that going to be a problem?
    Rodger
    I will give it a try.
    President:
  • 2,004 Answers
You might take the door apart but try seeing where the water comes from first by drying inside the fridge and really having a close monitoring.
I doubt if it's coming out from the door panel. Except the door does not close well and water drips from the items in the fridge due to loosing tightness.
Good luck.
Please rate this
Posted on Apr 21, 2009
  • Onifade Adewunmi
    Onifade Adewunmi Apr 21, 2009
    at wont be a problem.
    the door will fit in approriately. just be careful with handling please.
    Good luck and dont forget to rate my solution.
    Murphybanton
SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
How do I clear the frozen drain in the bottom of freezer?
Posted on Apr 06, 2008
SOURCE: Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Posted on Sep 19, 2008
  • 4 Answers
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
  • 72 Answers
SOURCE: Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Posted on Jun 17, 2009
MNfisherman
  • 11896 Answers
SOURCE: water leak from bottom freezer door
If you remove the back cover off the unit, you will see the compressor with an evaporator tray, make sure the little drain hose isn't plugged and that there is water in the evap tray from drain hose.
Posted on Jul 22, 2009
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
Water running out of tube from fridge into bottom of freezer door that leads up to water dispenser ?
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water comes out freezer door
Defrost that drain with a hair dryer and remove the debris . That should solve the problem . The red you see ( this is normal ) , is the defrost heater , thawing out the frost on the coils . The defrost water HAS to go out the drain or it will freeze the opening and the defrost water will flow out thru the bottom of the freezer door .
Aug 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking at bottom of freezer door where water line goes into door
DRAIN IS STOPPED UP! IS THIS A TOP AND BOTTOM OR A SIDE X SIDE?
Apr 27, 2009 | Freezers
Side by side leaks out front door on freezer side
Apr 19, 2009 | Kenmore Refrigerators
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from inside door
the water line for the water disp runs in a chase that goes up thru the bottom hinge of the refrig door. SO DONT PULL YOUR DOOR APART! you can order a new water line thru frigidaire and replace the part by removing the water dispenser housing on the door and pulling the line thru the door then inst the new line in reverse. if it looks like too big a job then get a reputable company to inst it for you.
Jan 21, 2009 | Frigidaire GLRT188WD Top Freezer...
Water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Aug 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire side by side, water leaking onto bottom of freezer
If you looked at the back section of the freezer (inside) and found ice then you need to completely defrost the fridge freezer. What you are describing is a frozen evaporator and the freezer needs airflow to work properly. If the unit starts behaving normally after defrosting then you need to monitor it closely as they will normally start playing up again after 2-3 weeks. If it does fail again then you probably have a defrost problem normally the defrost heater but can also be the defrost timer o defrost sensor. If it fails to reach temp then I would suggest contacting a decent repair guy who should be able to diagnose which one within a reasonable time. I would recommend defrosting first though because the same symptoms can happen when a door is left ajar. Hope the above is of some help.
Sep 14, 2007 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
