Question about Whirlpool Washing Machines
When washer was off it filled up with water and overflowed will a water inlet valve fix this. this is a whilpool washer frontload ghw9100lq1
    Sniper:
  • 88 Answers
Yes, it should. The only way water can enter a washer when off, is through a stuck inlet valve, or by siphoning water from a drain hose installed too deeply in the stand pipe. If your machine had enough water coming in to overflow, that definitely sounds like a bad inlet valve.
Posted on Apr 21, 2009
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Washer will not fill with water
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
Mar 06, 2014 | Amana Washing Machines
Water will not fill
Mar 04, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Water will not turn off
see this causes and fix it. God bless you
Water Inlet Valve If the washer is overflowing and power is shut off to the washer, the water inlet valve has failed. Replace it.
Pressure Switch If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
Low Water Pressure from House Supply If the washer is overflowing the water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the pressure is lower, the valve may not close fully when the power is shut off. This results in the valve leaking water into the washer and causing it to overflow.
Oct 16, 2012 | Maytag Washing Machines
Electrolux washer MEX731CFS0 overflows
Possible fault with the inlet valve section. It is possible that the inlet valve is open, clogged or is not working due to a faulty coil. also if there is no voltage from the program controller unit it will not be active. so check this voltage to the inlet valve to confirm.
click this link for tips : Inlet valve
Jun 25, 2012 | Washing Machines
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
At the end of cycle washer will not stop filling and overflows. maytag neptune fav6800aww
There is a diaphram switch located in the machine at the bottom right in the rear. When you remove the front panel it will be all the way back on the right. It senses the water level. It has three levels it detects. I had a problem with mine filling too much. That should take care of your problem.
Mar 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
Whirlpool washer duet ghw9100lq1
Hi. this issue is being caused by a defective flow meter. this is part of the water valve assembly but, its not integrate and it can be replaced separately without replacing the entire water valve device.
Simply replacing the flow meter will fix this issue. I have posted a link below that will allow you to purchase this part online.
CLICK HERE FOR YOUR REPLACEMENT PART.
Please rate and god bless:)
Apr 21, 2009 | Whirlpool Washing Machines
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
