Question about Sharp Actius MM20P (PC-MM20P) PC Notebook
Monitor gone bad
Couldnt find cursor--wouldnt restart
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    can you please explain in more detail what your problem is
    regards
Pc starts but black screen
Bad video card, bad hard drive, bios battery. If you have a screen but only a blinking cursor on it, likely a bad hard disk drive, meaning all your data and files are now gone, also your os is likely inaccessible. If you can heart it boot up like normal through speakers then video card or monitor, more likely the monitor's power supply is bad, find another monitor (size not important, just the display connector) and connect it to your PC with the power off. If it works then it's the monitor that is bad, purchase a new monitor, if another known working monitor doesn't solve the screen issue, it's probably your video card. A new card is cheap and you should be able to install a new one and have basic display until you install the drivers.
Sep 02, 2013 | Dell Inspiron 2600 1.2GHZ Celeron...
HOW DOES ONE CHANGE THE SIZE OF THE ARROW CURSOR ?
Go to start menu, accessories, accessebility, accessebility wizard, scroll down to magnifier and click
Apr 17, 2012 | HP 2009M Monitor
What would cause my 2000 gxsr 750 to shut down while driving? the speedometer went blank and couldnt restart.
Your battery has gone flat due to non charging by alternator.
Or it could be a bad or connection on power circuit, check main fuses etc, find out where power is going.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | 2000 Suzuki GSX-R 750
Menu stays on screen all the time and wont go off even when pressing buttons .Off On button doesn,t work either.Could cig smoke gum up buttons
Cig smoke wouldnt effect the buttons, the control board on the monitor is probably bad, this is what tells the monitor to display the menu, make changes, etc... If that has gone bad, pushing buttons would have no effect. Youre probably better off buying a new monitor.
Jan 20, 2010 | Computers & Internet
The monitor has gone to black screen and the on/off power button has gone to solid orange. How do I get the picture back?
This monitor has known problem with shorted out transistors (c3706/3707) in the inverter circuits. Also look out for bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 10, 2009 | Dell E173FP 17" LCD Monitor
CAR WONT START AFTER SHUTTING IT OFF FOR A FEW MINUTES
The battery has run down flat or the starter has gone bad. check the two.
Good luck.
Rate this.
Jun 10, 2009 | 1995 Buick Riviera
My Monitor Has Gone in Upside Down Positon
sure you have a Intel graphics card, with this cards you can turn the positioin of the screen pressing ctrl + alt + cursor (up, down, left, right)
try to press this combinations an you'll put your screen in order
bye
Carlos
Dec 31, 2008 | Belinea 19" LCD Monitor
Monitor goes black
If U can see the cursor then your monitor is fine, the culprit is your graphics card. It could be a virus, or a driver error. Try installing the drivers and check for viruses, if no help then Your graphic card is the most likely fault
Sep 11, 2007 | Acer AL1717 17" LCD Monitor
Sharp Actius MM20P (PC-MM20P) PC Notebook Logo
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
