Kenmore Washer I just can't figure this one out My Washer will fill up then it will wash for about 12 seconds and shut off, we have replaced the timmer. Can you help us. Kenmore Model # 110 92581200 Serial # CD 3229543
  • jr24 Jan 26, 2008
    cd1615561
    New Friend:
I had our washer repaired several years back and the guy said it was a problem with this model and we should NEVER use any cycle but the heavy duty. The only way to reset the machine was to let the machine run through its cycle one time (stopping and starting). Once it completes - everything goes back to normal unless somebody decides to switch the wash action to something other than Fast/Fast.
Posted on Dec 31, 2009
SOURCE:
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
My older model kenmore washer only fills with water when the hot or warm setting is on. When it's set to cold, either washing or rinsing, it stops. It will still agitate once filled on any setting. It...
You have said it all. OLD.
time to give it up and get a new one.
first, the cost of figuring out what part is defective and getting a replacement part may take a couple weeks and couple hundred dollars for the repairman.
second, you will STILL have all old parts on the rest of the washer.
third, if you buy a new washer, you have serious expectations of it working properly for at least 5 years.
Mar 08, 2018 | Kenmore Washing Machines
Kenmore washer 90 series will not fill up with water
You can shut off the water, then remove the hoses to see if the screens on the fill valve are gunked up. This is much easier to do than to replace the valve. I think you'll have sucess on that route :)
Aug 09, 2009 | Kenmore Washing Machines
Won' wash now
hi, from the sound of things you may have disconnected the pressure switch...here is how to figure out your problem...while washer is filling pull the plug....if water continues to fun your valve is stuck open...replace it...if the water shuts down you have somehow damaged or disconnected the pressure switch...the pressure switch is located in the control panel and has a plastic tube sticking out leading down to the side of the tub...make sure this is connected at both ends....if you dont see any problem replace the switch...hope this helps..please feel free to comment again if you have any other concerns....Good Luck!!!
Jul 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore HE3 washer
The water valve is not closing fully. You will need to replace the water valve.
Mar 31, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front loader trouble
If it is shutting off after a few seconds is the washer filling with water. If not you may need a water valve. If it fills with water then stops you may have a bad control and $350.00 is not really to bad for that repair. Besides if he is wrong he is stuck with the part not you. If he is correct then your washer is fixed and $350 is alot better than $1200.00 for a new one, so check that water and good luck to you. Mike
May 07, 2008 | Kenmore 44102 Front Load Washer
Kenmore Washer model # 11092581200
well im so proud my question was aimed at finding out if the motor was over heating but i guess you dont need me
Jan 27, 2008 | Kenmore 27032
Washing Machines Logo
320 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
