Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I turned the tv on and changed the channel. Now it says
Now it says "no signal" what channel does the tv need to be on?
    Genius:
  • Sony Master
  • 1,039 Answers
What inputs have you tested.If your sure about the program sources and still no signal then replace the AU board.
Posted on Apr 26, 2009
Lost signal
You have changed channels and now it's on the air. If your box is providing a signal on the 3rd or 4th channel you have to get back to those.
Aug 29, 2017 | Televison & Video
TV SHOWS WHEN TURNED ON NO SIGNAL
Is it all channels? Did you accidentally change your TV channel instead of your cable or satellite channel? Make sure it is on channel 3 or 4.
Feb 16, 2015 | Televison & Video
LG 32LH3000 is turning off when changing the channel
Do you have a box of some sort in line to the set for signal?
Dec 12, 2012 | LG 32LH3000 32" HDTV-Ready LCD TV
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
My 42" Vizio TV turns on and says No Signal, then
push INPUT on remote, select the input source you want, keep changing channel to find a exist channel.
Mar 25, 2011 | Vizio 42 in. LCD TV
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
I can get a picture , but no sound on the TV . What am I doing wrong?
Many RCA TV sound problems are caused by SAP function being activated by TV station equipment that converts Analog TV signals to HD signals. Accidental pressing of the wrong buttons on your remote can also cause this problem.
The incorrect conversions causes the Audio settings to be changed from Stereo to SAP by the received signal.
Solution is to go to Audio set-up in customer menu and change settings from SAP to Stereo. If you find that settings are wrong, change them to "Stereo". Do channel scan if you are using the TV tuner/remote to select channels. Turn off the TV and unplug for 60 seconds. Check the settings again and reset if required.
This problem may re-occur when you select the VHF channel, satellite channel or cable box channel that is causing the problem. It is not a TV fault that can be repaired. The problem is caused by the incorrect incoming signal.
SAP is Second Audio Program, used for second language transmissions.
Second cause may be that the speakers have been turned off in the audio set-up menu.
easyab
Apr 22, 2010 | RCA HD52W59 HDTV Projection Television
I need to reprogram my rcr317w remote contact with manual
Turn the tv on. Hook up your components, turn them on, go in to tv menu and auto program the stations. It will see that there is a signal on channel 3 and lock it in for you.
Jun 30, 2009 | Universal Remote Control DIRECTV Universal...
Converter box
You'll need to keep your TV on channel 3 or 4 depending on what channel you set the converter box. All your channel changing will be done through the converter using its remote control after that. If you change channels on the TV itself and go off channel 3 or 4, the TV will not get a signal and will show you that "no signal" message.
Nov 24, 2008 | Sanyo AVM-3259S TV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
