Question about Ruud UBHC Air Conditioner
Hi my myson orion has a pilot but nothing coming out of the main burners when demand for heat hot water, please help. cheers
  • 22 Answers
A furnace goes through more checks than the Shuttle before it lights! First, on the control board, are there any lights blinking, if it did light, there should be. Somewhere there is a placard showing what the number of blinks means; I need to know what is says on the placard. In the meantime, check the draft fan sensor - it looks like a small flying saucer towards the top. Blow and **** on the tubes and listen for a clicking sound and look for the presence of any water in that tube. That switch verifies that the draft fan is on and the mains will not fire if the control board doesn't get the proper sequence of signal......off, sensor open, fan on, sensor closed, verify pilot, fire mains, verify mains all it (sensor at opposite end from pilot). Hope this helps, if not, get back to me with that control board code. Ron
Posted on May 06, 2009
  • R. Walden May 07, 2009
    Correction: Lights should be flashing it it DIDN'T light
Richmond gas hot water heater. After I light pilot and main burner why does it flame out in 15 seconds?
If you had to light the main burner manually, something is wrong. Once you light the pilot and it stays lit, the flame heats the thermocouple to open the gas valve and fire the main burner. Either or both of the components you replaced could be defective.
Sep 10, 2015 | Water Water Heaters
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
No hot water coming out. ignition comes on ,but no lighting of gas. There is gas in bottle and it's on as normal.Works one day , doesn't the next.I cannot remember if there was a pilot light before!
check for pilot but im sure that the pilot is on demand thats what makes these things so cool and inexpensive to operate. try having someone turn on the hot water while looking for ignition. if there is nothing it may be a relay. im not sure but if you open it up check for a 3 amp fuse its green. all the new furnaces with mother boards have a fuse. I am not really a heating guy but i have been looking into on demand systems and sat in a training session at the plumbing supply. never hurts to try and help.
if its not a fuse or the ingniter isnt functioning you may need to call a heating person who knows on demand or check Bosch on line maybe they have the trouble shooting guide if you dont.
sorry that all i can suggest hope it helps
Dec 04, 2010 | Bosch & Tankless LP Hot Water Heater
I have a Bosch GWH 425 HN Tankless Hot Water Heater...On 2/28/2010, it began intermittant exploding when demand for hot water occurred. Local technicians worked on the unit several times, changed and...
I have the same problem with the same model. The problem has been identified by a friend of mine, correctly, I think.
This is a very dangerous problem involving Bosch's much touted safety feature, ironically enough. IT IS THE FLAME SENSOR IN THE GAS VALVE. The flame sensor is supposed to confirm that the pilot has lighted BEFORE the main gas line sends gas to the main burners, after which the pilot shuts off. The pilot light is not coming on, the sensor that shouldn't let gas fto the main burners is failing and the main gas is flowing and ignighting from the spark that is supposed to light only the pilot in a big explosion.
This is the 2nd unit of this model that has failed. I think Bosch should do a recall
Apr 25, 2010 | Bosch & Tankless LP Hot Water Heater
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Jan 25, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Hello we have 75 gallon Rheem hot water tank that was built in 2004. We have replaced most of the parts in the tank that control the fame opertation and we still have the tank when heat is called for, come...
i think the problem is when the demand for gas to the main burner is applied it robs too much gas from the pilot which causes the safety device to shut down the gas until the pilot is hot enough to open the main burner supply again. look for dirt or spider webs where the gas comes out for the pilot if none is found and there is no adjusting screw for the pilot flame then disassemble the pilot assembly and stick a needle inti the orfice where the gas comes out which will make the pilot flame a little bigger.
Jan 08, 2009 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
109 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
