What does acc mean on a car cd player - Audio Players & Recorders
Acc means accesorie a cable which only powers up when the ignition is on usual the blue cable on a iso connection (this is for an electric airal)
Posted on Aug 10, 2009
Radio will not work when car is running but will work when key is on acc
connect the red wire to acc fuse, the yellow wire to constant dc and the black wire to car chassis. probably you connect the black wire to the dimmer light
Oct 21, 2012 | JVC KD-G140 Car CD Player
What is ACC? From where it is connected From the ( - ) of battery
The ACC wire is a Switched +12 volt, usually from the Ignition switch.
Mar 09, 2011 | Panasonic Car radio CD CQ-C1110GN CD...
Where do you connect the memory wire on a jvc kd g110 car stero.....what color is the memory wire ?? what does hook red wire to acc fuse mean??? what wire does the red wire on the radio connect to on...
The yellow wire is most likely the memory wire as it needs to be connected to a constant 12 volt source.
"Hook red wire to to acc fuse" means you need to hook into the fuse block under an Accessory Fuse. (ie: something that can't be turned on unless the car is running or the key is in the "Accessory" position)
The red wire is explained above. It does not connect to the harness.
Just remember that the yellow wire needs to be hooked to a constant 12 volts and the red needs to be hooked to a circuit that is only active when the car is running or switched to the "ACC" position.
Mar 02, 2011 | JVC KD-G110 CD Player
Which is the remote cable for an amp on a jvc kd-lhx501 cd player
it will be the blue one you can also tap into the acc on the back of the deck(red wire) or the acc on your ing
Aug 17, 2010 | JVC KD-LHX501 CD Player
After i installed my alpine cd Player in my 2002 ford mustang I pressed the power/source button on the receiver and the engine started. What could cause this to happen?
when you push that power button it draws power from a 12volt constant and sends it to the acc on the deck witch tells it to turn on and off! this acc may be shared with the ing acc. now the only way that it could start your engine is if this acc is grounding out to stater,ing,acc wires etc,remote car starter involed?
Jul 24, 2010 | Alpine CDE-9852 CD Player
My radio and cd player or lighter doesnt work. but my clock does.....what is wrong!
Change out your ACC Relay. It is located on drivers side behind kick panel in fuse box. It is Black and rectangular shaped. Check for moisture. Many times water comes off driver door Chanel right into fuse box. Open driver door look for holes in front panel. ACC Relay is under 10 bucks at auto parts store.
Jul 04, 2009 | 2003 Ford Escape
CD PLAYER IN boat says ACCS and does not work, i have power and i checked the fuse's all working but the screen reads ACCS and i cannot remember how i fixed it the first time this went wrong,
OK, so I spoke with a Claion reseller and they were very nice and helpful. ACCS mode is accesory mode. This can happen if the brown wire in the back touches ground or the case on the radio. If it is not, tap the brown wire on the yellow(hot) wire and that takes it out of that mode. I tried it and it worked. Good luck! And thanks Clarion for your support on my 3 year old radio!
Apr 10, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Need Help !
Judging from the symptoms, I'd guess that "ACCS" means "accessory". All CD players have a constant power input and an accessory power input. There has to be voltage on both wires for the CD player to work, although the clock and CD load/eject functions will work with just a constant power connection. My guess is that there's an accessory switch somewhere in the boat that needs to be turned on for the CD player to activate. Failing that, if you can get the the wiring on the back of the CD player, the red wire is the accessory power wire. You can simply cut it and re-connect it to the same source as the yellow constant power wire. This will allow the CD player to work independently of any outside switches.
Jul 10, 2007 | Clarion M5675-RET CD Player
297 people viewed this question
 Grubhead
Grubhead
