Question about Patio Classic Barbecue Bucket Grill
My gas barbecue's ignition button does not work. i have a battery that came with it with no instructions.
  • lcorbett Apr 21, 2009
    can anyone solve this problem?
    Problem Solver:
  • 10 Answers
That battery is to go inside the button unscrew it from the front a spring will come out and you insert the battery inside the hole positive facing out screw it back together and bingo it will light
Posted on May 01, 2010
  • 490 Answers
Positive on the battery goes out but try to use a new battery not the one they sent with the pit
Posted on Apr 21, 2009
Poor flame after changing tank on gas grille
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Why won't the burners light even when I smell gas and hear igniter clicking?
Bill, two things possibly going on here that are common with an aging grill. First you need to turn off the fuel tank and set it aside. you mention that a clicking can be heard when pushing the igniter button which usually indicates good battery but if you have never changed it you may want to just as a good measure. Unscrew the bottom and you should find AA or AAA battery behind it. Now with battery good and the igniter generating a fast load clicking sound you want to get down and follow the wire that runs from the the back side of the igniter push button down inside and usually under the burner tubes ending out at one end of each burner. What happens when you press the igniter switch is, an electrical current is sent down the wire and when it reaches the end the current jumps to the closest metal it can find creating a spark.so you need to insure that the end of the wire is close to where the flame is generated but not so close that that you cant see a spark. Make sure the end of the wire is bare and clean as is the area on the burner where it arcs Now do this to all for burners. Turn all the knobs on the grill off and connect the tank. Make sure the lid is open now, and slowly open the valve on the tank. I say slowly like a ten count from close to full open. what can happen if you crank the tank valve open too quickly or with the grills valves open a vapor-lock effect can be created greatly reducing the flow of fuel from the tank. Iv'e seen many of the uninformed return 1/2 full tanks due to this problem. If you notice week flame or no flame but smell gas ALWAYS SHUT OFF VALVE ON TANK IMMEDIATELY KEEP LID OPEN AND LET THE AREA VENT BEFORE TRYING AGAIN lest you be the one being barbecued. Good Luck
Apr 27, 2014 | Kenmore 16225 Grill
Have brand new 810-3330-s brinkman grill main igniter is receiving no gas, is there a screw to adjust flame?
BEWARE: DO NOT TRY SUCH HAZARDOUS TRICKS YOURSELF AS LOCATING A SCREW TO ADJUST GAS PRESSURE. CONTACT THE DEALER OR AUTHORIZED CUSTOMER CARE.
Mar 29, 2014 | Brinkmann Brinkman Barbecue Grill Gas...
I have got a gas cadac barbecue but it no longer lights from the ignition, is there a battery that can be replaced in it? Many thanks Diana
We have same problem with ours - hardly used as well. Have been informed by Riversway leisure - where we bought it, that we need to buy whole unit it is connected to and that you cannot just replace piazzo igniter. You'd be better off just buying a hand held piazzo? igniter - cheaper!!!!
Aug 17, 2011 | Garden
Can not light flame
Gas is on. Look to see if the magneto is working properly. Do you see a spark when you press the ignition button? Perhaps the magneto gap is too much or the gas is not in contact with the spark.
Aug 16, 2010 | Char-Broil CharBroil Master Flame Gas...
Gas grill prob.
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Also, when you lite the BBQ, make sure that you turn the gas on at the tank, wait a couple of minutes and then turn the knob on and light the burner. This is to make sure that the pressure is regulated and sufficient prior to lighting.
Hope this helps!
Sep 01, 2008 | Grilling
Converting LP to NG
The install manual on the dacor web site insists that Natural Gas requires the nozzles be removed, that low pressure NG works with the large 'default size nozzles'. Have done the conversion, in Australia, for my own barbecue, worked ok
Gas is too dangerous to make mistakes with. All I can suggest if Dacor is difficult is take the pdf of the installation instructions, link in the first replies, and the barbecue to a local gasfitter/plumber and ask them to work on it. they will be able to do the calculations from the existing nozzle size, lpg pressure, ng pressure, and required BTU output, to put in correctr nozzles
Dacor Australia are much easier to deal with.
(Now res in Canada,)
Bob
Aug 08, 2008 | Dacor Preference SGM365SS Gas Cooktop
Char-Broil Advantage 463453306
I dunno, I have not done the conversion for this particular barbecue, but the kit is listed in the parts list for that barbecue,
It would be appropriate at this time to print the conversion instruction manual and take it to a local 'guy' a gas fitter.
The instruction .pdf shows them converting 3, 5, 7 burner units with the same kit, and states
  • Insert orifice removal tool provided with kit onto firebox burner openings and unscrew orifices from valves.
    Save removed orifices for later if converting back to LP Tank Gas.
    The valves are designed to work with natural gas once orifices are removed.
    Do not replace any Orifices when using natural gas.
    NOTE: your gas conversion kit comes with replacement orifices for the Rotisserie Burner ONLY, do not use on Tube burner valves.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/assembly%20manual%20-%204584609%20ng%20conversion%20kit.pdf
seems the same 2-burner kit is for all barbecues
I think the person on the phone messed up, but a gas-guy would know for sure
Jul 01, 2008 | Char-Broil Advantage 463453306
Bunners do not get hot
Hope this helps!
Apr 20, 2008 | Coleman LG40811E Grill
My baby q is sick
Since 1995 all regulators (the part that attaches to the gas tank to regulate the flow of gas) have included a safety device that restricts the flow of gas in the event of a gas leak. This safety device can be inadvertently activated in two ways, putting the grill into what is commonly called “bypass”. The first way for the device to be activated is to leave one or more burner control knobs in the “ON” position when the LP cylinder valve is opened. The second is not to wait long enough to “start” the grill after opening the LP cylinder valve. The safety device in the regulator is activated each time that the LP cylinder valve is opened. The device resets itself when the gas pressure equalizes between the closed burner control valve and the regulator, through the hose. If a burner control knob is turned on before the gas pressure can equalize, the device will remain in “bypass”. The length of time necessary to wait to “start” the grill after turning on the LP cylinder valve is dependent on the length of the hose and outside air temperature. It is always good practice to wait a few seconds after opening the LP cylinder valve before turning on the burner control knob to start the grill.
Keep in mind that the safety device reacts to a gas leak. If a grill is in bypass, the gas connections and hose should be tested for leaks with a soap and water solution.
If the grill is in bypass, after checking for gas leaks do the following to get the grill out of bypass:
To reset the gas safety device:
Open the barbecue lid.
1. Close the LP tank valve.
2. Turn your burner control knob to the OFF position.
3. Wait at least 5 minutes if the barbecue had been lit, then
4. Disconnect the hose from the LP tank.
5. Turn your burner control knob to the HIGH position.
6. Wait at least 2 minutes, and then turn the burner control knob to the OFF position.
7. Re-connect the hose to the LP tank.
Re-lighting the barbecue:
1. Open the barbecue lid.
2. SLOWLY open the LP tank valve all the way and wait 1 minute.
3. With the lid open, turn the burner control knob to the HIGH position.
4. Ignite the grill by pushing the crossover ignition button.
5. Close the barbecue lid.
6. The barbecue should reach 500 to 550 degrees in 10-15 minutes.
When you are done grilling:
1. Turn all burner control knobs to the OFF position
2. Turn off the LP tank valve last.
* Always follow the re-lighting instructions whenever you use the adapter hose and larger tank.
Feb 16, 2008 | Weber Q Grill
Patio Classic Barbecue Bucket Grill Logo
719 people viewed this question
Top Patio Classic Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Patio Classic Grilling Expert? Answer questions, earn points and help others
