Question about Hitachi 51F59 51" HDTV Projection Television
Red shadow on TV Screen Hitachi HDTV
We have a Hitachi 46" TV, about 3 years old, and all of a sudden everything is in duplicate/triplicate. There is a red and a yellow "shadow" outline to the right of each thing on the screen.
  • 65 Answers
Your convergence is bad. You need to have convergence amplifiers changed.
Posted on Apr 22, 2009
  • Hitachi Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and Red shadow on TV Screen Hitachi HDTV - 2c07611.pngeplaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 24, 2009
My television is only 6 years old. Red lines have appeared in the form of a wave pattern on the screen. What does this mean?
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have a colors shadows or 3D pictures look alike?Ur tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 27, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
We have a 46" Hitachi TV that suddenly after the cable man hooked up a new receiver box has gone funky! The top left of the screen is wavy down about a third of the screen and the wording is...
What you just described is a convergence issue, Now most tv's have a auto focus button on them or the remote try giving that a push (if your tv has it) I cannot go by the model above because fixya has categorization errors or people select the wrong tv.
But this is a convergence issue if the focus button does not take care of it your going to need repair.
thanks for using fixya.com , please do leave positive feedback or ratings, Thanks
Aug 26, 2010 | Hitachi 46F500 46" Rear Projection...
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Dec 15, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Red ghost image or shadow
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
rate me
Jun 11, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Tv out of focus
Your convergence ICs need to be replaced. Please respond to this same post and verify your model number and I will post the correct ICs for your model and post a link where you can get replacements with free instalation instructions.
Aug 01, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
My Hitachi 43" HDTV shows double vision with shadows on people and words> I have tried to adjust everything with the remote but that does not work. Maybe there is a remote feature to fix this that I dont...
Is it a rear projection tv? if it is, then the problem is the convergence board. convergence ic need to be replaced. and this can be done by an experienced technician or if you are good in soldering, you can do it yourself.
Jun 06, 2008 | Hitachi 46F510 46" Projection HDTV
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Hitachi big screen tv
Convergence IC's bad==replace and then
re-check alignment
Oct 16, 2007 | Hitachi 46F500 46" Rear Projection...
Hitachi 51F59 51" HDTV Projection Television Logo
972 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
