Question about SanDisk Sansa e260 MP3 Player
Battery life even after getting a new battery I am only able to get about 5 hours of battery life??
  • Anonymous Jan 22, 2008
    ok, I have a sansa. It's about 6 weeks old.
    I charge it to full charge and the next day the battery is at 1/2 charge. I have not turned it on but there seems like there is something that stays on in the machine therfore dropping the battery charge time. It's really irritating.
After spending many hours with on the phone with scandisk, intalling a new battery, reformating the unit ect. I found that the only solution is to take it to the retailer, obtain a refund and buy an Ipod Nano for about the same price
Posted on Oct 11, 2007
Charge it 4 longa coz itz new
Big blue speaker repair
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
If the speaker is under warranty get it replaced.
Taking the speaker apart to replace the battery will compromise or even destroy the acoustic properties of the speakers. Big Blue Live Wireless Bluetooth Speaker
Mar 09, 2015 | Brookstone Big Blue Studio Wireless...
Flat battery
There are 2 possible causes here. Either there is a voltage drain from something on the bike or the battery is discharging on it\'s own accord. If it is a wet battery (ie non gel type) often when it is new and first acid filled some people make the mistake of quick charging them straight after filling. What then happens is the battery only gets a surface charge, so it will charge up to ie; 12.8 volts fully charged but have no cranking amps. Secret is to fill the new battery with acid then let it sit for an hour to get full penetration of the plates then slow charge it for 4 to 5 hours to get good battery performance and life.
Nov 29, 2013 | 2006 Yamaha YZF-R1
When I plug in the adapter to the charge the consol the orange light lit. The light does not turn off even after 13 hours of charge. After 13 hours when I want to use it, the red light comes on not the...
Hello there. You may need to replace your battery pack, as leaving it charged for over 4 hours can lead to "overcharging" a condition which can dramatically shorten your battery packs lifespan and charge retention.
Also, be sure to charge your console while the device is turned off. Although you may charge it while it is powered on, it will take longer.
As stated, be sure not to leave the system on charge for more than 5-6 hours, as this can damage the battery and is liable to cause battery leakage, burning, or overheating.
Battery life is largely dependent on the game being played - some games can give you up to 10 hours of battery life, though the real-world estimate is really more like 5-7 hours of constant use before you'll need to recharge.
I hope this helps you. -
Frankie.
May 11, 2011 | Nintendo DS Lite Console
Battery runs down in about 5 hours without using
Hello, I have just published an article on how to save your battery life as I had your problem too. There are around 10 tips in my article to save battery life. Here is the link.
http://www.fixya.com/support/r4079271-tips_hints_maximise_iphone_3gs_battery
All the best
Jim
Jan 21, 2010 | Apple iPhone Smartphone
Short battery life
Battery life on laptops is like the mileage estimates on new car windows....it's wishful thinking. You would have to set the power management to shut the screen off after 5 minutes of inactivity, shut the drives off after 6 minutes and send the thing into hibernation after 10 minutes to get better batttery life.
Sep 06, 2009 | Samsung NC10-14G Notebook
Battery does not charge
Will the old battery (that you are replacing) charge up at all? If the old battery charges but the new battery will not, then it's likely a bad replacement battery.
To rule out the possibility of a corrupted battery meter inside of windows, you may wish to leave the laptop on battery power only, until it dies. A 5% charge will usually only grant you about 20 minutes of laptop life maximum. Since you left it charging all night, you should get a few hours of life before it dies. If you get a few hours of life, the battery meter software is corrupted.
Most likely though, the replacement battery is bad.
Sep 02, 2009 | HP Compaq Evo n610c Notebook
Charging new battery
usually 8 hours.
for first charge.
on a brand new battery
Jan 29, 2009 | IBM ThinkPad T41 Notebook
Insignia Pilot 80G MP3 player battery life
Hey General Chao,
Unfortunately, battery life can largely depend on how any given device is used - the louder the speakers or the brighter the LCD screen, the shorter a battery will maintain its charge. The 25-hour battery life quoted by the manufacturer may simply be an estimate based on the lowest possible settings for player volume, backlight and display settings. This means that the average user will probably encounter a significantly shorter battery life, especially when using maximum volume settings to compensate for ambient noise or other interference.
If you're still concerned, remember that you can always contact the manufacturer for further assistance at their toll-free hotline: 877-467-4289. Should your MP3 player be suffering from an actual hardware failure, Insignia may be able to provide you with additional trouble-shooting support or repairs if necessary.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 16, 2008 | Audio Players & Recorders
Battery life under 5 hours
have you let the battery go totally flat as this is recomended to do every couple of months because if you dont let the battery go totally flat this stops the battery from full recharging and will cause bad cells in the batt so i would let hte battery totally flat till it wont even light phone up then fully charge for 16 hours see if this improves the battery if not then the charger is probably over heating and cutting off so you could replace the charge hope this is some help to you
Nov 19, 2007 | Samsung SGH-D900 Cellular Phone
SanDisk Sansa e260 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
