Question about Krups ProAroma 453-71 Coffee Maker
Need to find source for thermal cutoff assembly/fuse
Need to find a thermal cutoff assembly/fuse for a Krups type 212 household coffeemaker. Relay is a stud mounted device with quick disconnects and markings: Z42/43 , 10/250 "cycle mark" and T 250. Any help on where to find a replace part would be appreciated.
5 Suggested Answers
  • 36 Answers
SOURCE: krups water level problem
cpg1959:
it looks like your coffee maker has a LCD display panel driven by a discrete electronic circuit board inside. similar to brita water filter which is driven by an integrated circuitry. be honest with you, many manufacturers' product designers, especially today's new generation, they only look on good and fancy side and forget about durability, yielding a lot of junk products. unless it is still covered by warranty, otherwise, don't spend good money on bad, just ignor the warning, or disable the warning if you could.
pc-cook
Posted on Jan 25, 2008
SOURCE: need Manual for Krups coffeemaker AG E 15 - can't set time
I went to the Krups web site and pulled a copy of the manual for a different model with the same user interface. This solution worked fine. My model (on the baseplate) is AG E 15. The manual that I printed was for a FMF5. Cheers!
Posted on Apr 01, 2009
Sebin
  • 712 Answers
SOURCE: Krups FMF5 coffeemaker- coffeemaker begins to brew
Check for any blocks in the route of water from the reservoir. And do not try to run the machine several times before the problem is rectified. It may cause further damage.
Posted on Oct 08, 2010
GodBlessU
  • 3513 Answers
SOURCE: I need a replacement for
Please find the links bellow from where you can get the parts:
http://www.scribd.com/doc/9633532/D150InstructionManual
or
Try www.espares.co.uk
or Currys partsmater
www.Wholelattelove.com
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Posted on Oct 17, 2010
I need to replace my Krups 453 Thermal fuse (ms-0061607). Where can I find one or is there a replacement?
They are obsolete and quite a high temperature rating for a coffeemaker (300 deg C) You could get someone to replace it with a 240 deg C microtemp and see how that works out, boiling is 100 deg C and coffee goes into your cup below that so it is quite reasonable to expect 240 deg C to be fine. I'm pretty sure that is the highest temperature microtemp available.
Jan 05, 2015 | Krups Coffee Makers & Espresso Machines
Pluged coffeemaker into power, time went on, then no power at all
powerr short in the connection.check it properly.
thanks.
Sep 23, 2008 | Cuisinart DGB-600 Coffee Maker
It says the water reservoir has not been filled even when there is water in it. I'm unable to make coffee and keep getting this error signal.
The thermal cutoff fuse is bad. Fuse is located on the side of the heating element. No continuity will indicate failed switch. replace as assembly with heating element.
Sep 18, 2010 | Krups FME4-11 12-Cup Coffee Maker
Krups KM7005 coffeemaker/grinder does not heat or drip the water
The heating plate is actually your hot water heater for the unit and it has most likely failed. The water flows through the heating plate and heats the water for brewing. Krups replaced my whole coffee brewer.
Dec 15, 2009 | Krups Small Appliances Espresso Machine
After grinding the coffee the water will not percolate through
Yea this seems to be the number one problem with this coffee maker. Apparently this unit has 2 thermal cutoff fuses that are perhaps a little under rated for this unit. Replacing them requires a triangular head screwdriver and a soldering iron to de-solder the thermal cutoff fuses and solder new ones in. your best bet is to have an appliance repair shop fix it up
Nov 14, 2009 | Krups Coffee Makers & Espresso Machines
Krups KM7000 grinds but won't brew, warming plate no heat. Is this repairable, (perhaps a fuse?) or is it junk. Bought the machine in March 2008
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Oct 30, 2009 | Krups KM7000
Krups model KM7005 water wont heat
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Apr 10, 2009 | Krups Coffee Makers & Espresso Machines
Need instructions for a Krups Household Coffee/Espresso Maker
Go o krupsusa.com and click on "instructions" they should have it
Dec 11, 2008 | Krups Small Appliances Espresso Machine
Krups ProAroma 453-71 Coffee Maker Logo
176 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
