Question about Logitech X-530 Computer Speakers
Speakers not working correctly
I just set up my Logitech x-530 speakers, but the configuration doesn't seem to work correctly. I am getting sound from all speakers, but for instance, when I run the "test" for speakers, I get the sub woofer sound from the right rear speaker, the rear speaker sounds from the center channel, etc. I am running Windows Vista Ultimate, if that helps. Please help! Thanks!
  • 8 more comments
  • Copasta Sep 24, 2007
    Already fixed....I didn't realize that my system was set for 7.1...thats why the configuration was all screwed up. Once I changed settings from 5.1 to 7.1, then cancelled out the rear speakers for the side speakers, everything worked like a charm! Thanks for the help, though!
  • yahooelias Nov 03, 2007
    Dear sir,
    I am having the same problem as you
    How do I solve it?
    I test the speakers they are all working. When I play a 5.1 DvD eg Top Gun all my speakers work but except the rear 2 speakers dont work please help me
    my email address is [email protected]
  • Anonymous Dec 01, 2007
    my speakers all work when I run the test but when I play music the rear left and right speakers do not work
  • Rudy Creel May 04, 2008
    I Bought the X-530 from Logitech, all speakers worked, but when I get the connections in place just 2 sound, and the back speakers and center don't, any help?
  • Anonymous Jun 14, 2008
    i have the same problem, i changed it to 7.1 and swapped the rear speaker plug into the side speaker plug but it still swaps the sub for the rear right.... please help.
    [email protected]
  • Copasta Jun 19, 2008
    In my earlier post, I stated that I switched from 5.1 to 7.1. I'm sorry, but this is incorrect! It should have read I switched FROM 7.1 TO 5.1! Thats when everything worked for me! Sorry for the misprint!
  • dfor7292 Oct 15, 2008
    hi have logitech x530 speaker and the middle one does not work only if i plug into different speaker hole can any help my email is [email protected]
  • noor_zain12 Jan 26, 2009
    yes i have the problem sound is comming but speaker is not working i think setting is changed
  • Anonymous Jan 28, 2009
    i puring a new windows in my computer and dont work
  • Anonymous Mar 22, 2014
    only the sound from my pc monitor is working all speaker are hooked up right
You need to activate speaker fill i the settings
Posted on Jun 19, 2008
    President:
  • 2,022 Answers
Pls swap the spk pin in to your sound card jack socket . bye
Posted on Sep 24, 2007
SOURCE:
Hi, I bought recently a new 5.1 Surround Sound System Logitech X-530 and want to connect it to our new LCD LG 32LD450 HD TV. The LG TV has apart from all Digital, Optical and RCA Connections as well one...
You can't connect the speakers to your TV. I doesn't have any audio output available, just inputs. Those are for connecting the audio from sources like DVD players, and they go in to the TV's sound system. But there's no way of getting the sound out except through the set's internal speakers. The surround system you got is great for a computer, but it's not what you need for TV use.
The only solution I can offer is the suggestion that you invest in a home theater receiver. You can get decent basic systems with the receiver (often with DVD/audio CD playback capability built in) and surround speakers at reasonable prices. Then you use that to drive the speakers, and use the TV just as a video monitor. Then you will have surround sound.
Jun 01, 2011 | Logitech X-530 Computer Speakers
I bought a x-530 5.1 and i cant seem to get all the speakers to work
First you have to connect them correctly to your sound card (green=Front, Black=back, orange= central+woofer)
Then set your sound card from it's drivers to 5.1 output.
All 5.1 sound cards should have a 5.1 sound test for each speaker, if not try a mp3 in windows media player.
Remember you have to set 5.1 output in each program to have sound in each speaker.
Feb 14, 2011 | Logitech X-530 Computer Speakers
I need a logitech x-530 driver for my ibm thinkcentre
well
No speakers ever need drivers.Excluding, usb speakers.Its the same case with you also ....You need to configure the settings on your sound card...go to the following link to check your speakers settings how to test :
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=2913&p_created=1125714076
good luck:-)
Apr 09, 2010 | Logitech X-530 Computer Speakers
How to connect 5.1 intex speakers
your problem is you have a very nice 5.1 speaker set but you have not configured your system to use the 5.1 configuration.
if you are using the realtek drivers, then try to open the configuration panel,
and in the control panel try to change the default sound configuration to 5.1 surround sound configuration. then all your speakers will work.
hope this helps
Feb 05, 2010 | Logitech X-530 Computer Speakers
Only two speakers are working I have vista ultimate install in my computer , I have logitech X-530 speakers
Helllo there!
You have to make sure you have in control panel your audio sound card, well installed and is working right. Then go to control panel and see your speaker configuration, is suppose to be at 5.1 speakers also you can use 6.1 Speaker configuration. Be sure you connect right your speakers at back of the audio jacks!
that's it!
good luck!
Open Sky
Dec 08, 2009 | Logitech X-530 Computer Speakers
I have logitech x-120 speakers and cant get any sound out fo them
I have logitech 530 speakers, can only get 2 speakers and sub to work. Just installed new sound card. When I run a test on all speakers they work, till i try to listen to music, then only 3 work
Mar 09, 2009 | Logitech X-530 Computer Speakers
My speakers dont work , only my subwoofer
Check you sound properties. The computer may not have configured the speakers properly. Make sure the speakers are listed and that the correct drivers are installed. Doublecheck that you have the plugs in the proper jacks. Hope this helps.
Mar 08, 2009 | Logitech X-530 Computer Speakers
Logitech x530
I have had this a few times with customers. You might want to check if the sound cards front speaker ports are working correctly. If the card is working, the problem might be with your right front speaker, ckech that it is working. You might also want to check the settings in control panel; this has helped me a number of times.
cheers
Oct 05, 2008 | Logitech X-530 Computer Speakers
Logitech x-530 speaker problem
Try going through this troubleshooting procedure site first: http://logitech-en-amr.custhelp.com/cgi-...*uWZ8vi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzgmcF9wcm9kcz04NDQsMTcmcF9jYXRzPSZwX3B2PTIuMTcmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9Mg**&p_li=&p_topview=1 If you get no solution from this, there are other similar logitech speaker systems that have had similar problems on initial models. it appears that logitech have been very helpful with replacing speakers in the past if design or product is faulty. Give them a try. hope this helps:)
Feb 21, 2007 | Logitech X-530 Computer Speakers
Logitech X-530 Computer Speakers Logo
1,410 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
