Question about LG GSA-H55N DVD-RAM Burner
Hp dvd/rw does not read discs
Any disc i insert does not read discs,,,, trouble shoot program says unit is working properly
    Brigadier General:
  • 10,406 Answers
If the CD or DVD disks you inserted work in some other reader, then your reader is the problem -- even though it is properly connected to your computer, and Windows has the correct device-drivers, it is the "hardware" that is the problem.
When you insert a disk, rotate it to some position, i.e., top-lettering goes in first, and close the drawer. Do you hear the drive start to spin the disk? Open the drawer. Is the disk in the same (non-rotated) position? If so, then the motor that spins the disk is the problem. If the disk does spin, but nothing happens, then it is the "laser" part of the mechanics that is not working.
Replace it.
Posted on May 14, 2009
Insert disk all i get i load then it eject disk
Well it seems that your DVD player is having an issue reading the disc, I guess the first question is what kind of disc are you trying to insert? Is it a burned DVD or is it a movie dvd? This model is not a Blu Ray so if you are trying to use a Blu Ray disc then it will not read it. If you are trying to read a burned disc from someone then more then likely the disc was not finalized and is unable to recognize the disc, because the finalization process is where all the the information is written about what kind of disc it is and the format, codecs, etc. OR maybe the laser is dirty or the DVD player has kicked the bucket. Finally, the product DESC says it can read DVD-RAM, DVD-RW, DVD-R, DVD+RW, DVD+R, VHS formats, but I have found that some DVD units do not like certain brands of Blank DVDs. I hope this offers some ideas for you and good luck!
Oct 29, 2013 | Samsung DVD-VR357
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Finalizing
Use a name-brand DVD, such as HP, Verbatim, etc. and make sure it is a DVD+R or DVD-RW/-R disk only.
It is most likely that the DVD you are using is not compatible.
The disk is still usable, but you can only read it on that player.
Aug 17, 2009 | Funai PY90DG DVD Recorder
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
Samsung SHW08A DVD±RW doesn't burn dvd+r
Its because you need a firmware update. The media you are currently using isn't recognized. I stumbled in here with the same problem. I haven't been able to find an update, so I will probably have to try a different brand of disc myself. The burner worked fine until I tried using a new pack of Verbatim discs.
May 21, 2008 | Samsung SH-W162C 16x16x8x6x5x4 DVD +/-...
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
LG GSA-H55N DVD-RAM Burner Logo
403 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
