Question about Altec Lansing inMotion iM7 (021986950806) Docking Station
IM7 No power. Found out that the plug in switch
IM7 No power. Found out that the plug in switch which changes it from battery to 110 had failed. Soldered wire direct and bypassed the jack. Only 110 now. The jack might be able to be cleaned. Now the on off switch has failed. Anyone know where to get on??
Re your IM7 'plug in switch' which changes it from battery to 110-----where is that switch located, and how much of the unit did you have to disassemble to get to it? Thanks
Posted on Jun 19, 2009
Bonjour, je suis Français sur Apple G5 avec traducteur : Doesn't my IM7 function any more, more indicator of starting? does the tranformator function to him well, there has to you it a handling to make or is you it broken down for good? Thank you for a
Posted on Feb 14, 2010
Why did battery go dead while the RV was plugged into 110 power?
there can be several reasons why your battery can go dead you kind of have to diagnose one step at a time. are you sure that your converter is working correctly on some of the RV's there's a switch you have to flip that switch to make sure you're charging batteries while plugged in It could be a fuse problem there are a number of things it might be or the battery could just not be good check your fuses would be my first suggestion make sure you got power coming in let me know Thank You Billy
Dec 31, 2015 | Forest River 2012 Salem Villa Classic...
How to fix couple of DELL desktops where I plugged them into 220 volts Power supply when they were set for 110 volts? More details below.
you could try replacing the power supply. if it still does not work, you probably fried the processor or motherboard. (or both). just make sure the replacement power supply has the same type of connectors on the power leads to the motherboard, hard drive, etc.
Aug 15, 2015 | Dell OptiPlex Computers & Internet
1210 conversion from 220 to 110. Uk deck to US use. Have found switch and now need to change plug. Uk plug is sealed. Do I just cut it off and rewire to a US plug? What's wire to which part?
Yes, just cut off plug and rewire...these will not require a 3 wire connection unless the UK plug was 3 wire so either wire can go to US ungrounded plug on either side. The audio is entirely separate from the AC power.
Mar 08, 2014 | Technics Audio Players & Recorders
I accidentally plugged computer avr 220v to 110 could it affect my power supply
If the computer power supply is a 240 volt unit and you plugged into 110 volt mains the the computer should be OK.
Some power supplies have a voltage selection switch on the back of the power supply switch to 110 volts and it should work.
If the power supply is 110 volts and you plug it into a 240 volts mains then you will damage the power supply and possibly the computer as well.
Mar 14, 2012 | HP Pavilion a465w-b PC Desktop
My altec lansing im7 stopped working during class
I am having the same problem. Did you ever figure it out??
Jul 28, 2009 | Altec Lansing inMotion iM7 (021986950806)...
Sparepart For Im7! LOOK HERE!
I have one that just quit all of a sudden as I was listening to it. Don't know what happened, but it "clicked" and that was it. Sounded great while it was playing, I have the remote if you are interested.
Jun 27, 2009 | Altec Lansing inMotion iM7 (021986950806)...
Cannot turn the system on
trouble shooting info here:
http://www.fixya.com/support/p731114-altec_lansing_inmotion_im7_docking_stat/manual-25062/page-5
Feb 15, 2009 | Altec Lansing IM7 (WMM137039)
It want switch on
My Compaq Armada 110 does the same thing from time to time. Most of the time, the best way to have it power back on:
Unplug it. Pull the battery out. Plug it back in without the battery. if you get a light flashing to the left of the top section above the keyboard, you're set. put the battery back in and power it on. if still no flashing light then next:
unplug the unit, pull the battery, flip the unit upsidedown and open the panel with the two screws to the right. reseat the memory modules in the sockets there. then reassemble, the plug the unit in without the battery. if you see the light, then put the battery back in and you're set. power it on.
if it still doesn't power on, i've got other suggestions but these are the main things I have to do to get mine working. :)
Nov 26, 2008 | Compaq Armada 110 Notebook
Altec lansing im7 does not power up!
Altec no longer makes the power supply. However you can find used ones on eBay for about $25. I went to my local electronics store and bought an 18V, 2 amp power supply for $14. It works great and charges the iPod just like the OEM power supply. The store I purchased it from is JK Electronics in Westminster, CA 714-890-4001.
Jun 07, 2008 | Audio Players & Recorders
Vhs pal video not working
Change the DIP switch to PAL, unplug the unit (no power), then plug it back in. You need to power-cycle the unit to after changing DIP switch settings.
Also make sure that your capture application is set to PAL mode, if there is a NTSC/PAL setting.
Nov 22, 2007 | Canopus ADVC-110 A/D Converter...
Altec Lansing inMotion iM7 (021986950806) Docking Station Logo
1,197 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
