Question about Nintendo Wii Console
We cannot get the wi to connect to internet.please help
  • John Andriessen May 11, 2010
    What is exactly the problem?
  • 864 Answers
Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
Hi, I cannot connect to the internet although my internet connection is fine, I can connect with a a inthenet cable, and I have rebooted etc.. can you help please, Dave. Model no Acer Aspire E1-571
Make sure that the wi fi adapter/chip is working. Go into device manager and uninstall it and reboot. If still n connection and you are sure that your network is up and running try using another external wi fi adapter on the premise that your existing unit is bogus.
Jan 16, 2017 | Acer Computers & Internet
Wi fi will not connect to web
hi please check your internet security settings
Feb 17, 2012 | Acer Aspire One D257 Netbook
Describe your 7" G-Netbook
There may be many reasons for this. Please check the following things one by one.
1. If you have another known good laptop then try it with your wi-fi router. See if the wi-fi router is able to connect to the internet
2. If you don't have another laptop then use an ethernet cable (RJ45) cable to connect to the wi-fi router. See if this helps.
3. While connected with the wi-fi router see if you can access the router. open any internet browser and type 192.168.0.0. you should get the router page. If you don't get then you have to configure the router first.
4. Check the internet settings of your browser. There will be "internet options" or similar in the menu of your browser. Click that. In the GUI you will get "connections" tab. Click that and select the proper wi-fi setup.
Jul 28, 2011 | Sylvania G-Netbook
Internet settings
Hello there!
You may connect to the internet in 2 ways, via Wi-fi and GPRS.
For the GPRS, you need to contact your Network Provider to send you the over-the-air updates on GPRS setting to your phone or you may visit their office to set it manually.
Using Wi-fi, you may connect thru it, but please note that some Wi-fi connections requires password.
Regards,
fossildude
Mar 04, 2011 | Sony Ericsson P990i Smartphone
I cant get internet on my itouch although im connected to a wi-fi
My mp4 turns on and the screen turns blue and then it says loading.I cant get it to do anthing past now loading.How can i fix this,?i have tried everything.
Feb 24, 2009 | Apple iPod touch
Will not connect to the internet
You can only get internet from an Internet service provider.
You need to connect wi-fi point to telephone line (ASDL connection) or to modem from cable company. Otherwise you can only get Internet from someone elses Internet service provider.
Jan 04, 2009 | Toshiba Satellite A100-S8111TD Notebook
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Wifi not function
My Internet service provider walked me through connecting correctly. I had chosen the WEP security options and should have chosen the WPA-PSK option. Call your service provider and get them to help verify your security access codes.
Sep 26, 2008 | Palm LifeDrive Handheld
Help
how to reset imate
Dec 08, 2007 | i-mate K-jam Smartphone
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
