Question about Dishwashers
Error code A09 - Hotpoint aquarius fdw70
I have had heater problem with my hotpoint fdw70 dishwasher at first. I Changed that. Then I had Float swith problem. I sorted the leak. Then I went and accidentally got the wires wound up and made a short-circuit which even triggered the house mains switch-board. Something started to smell from the module box! I have replaced that. Now I am getting A09 error code. What does this mean!? Please help!
  • 114 Answers
SOURCE: I have a Hotpoint FDW70 dishwasher
Disconect POWER at breaker or fuse panel which should be on a seperate braker. if not find the power sorce and unplug the device. FOR SAFTEY Kneel on a thick doormat if you have to disconect power which has a plug. Wait for a an hour so to let all circuits, timers and motors to cool ... with diswasher in the OFF position, Re-establish POWER. then go ahead and start washer as sugessted by the Manufacturer. Make sure to notice any other codes that may appear. Or any peculiar noises. Most default codes appear if water pressure is too low. Top loaders are natorious for plugged drain lines and can be flushed by the home-ownwr. Make sure to check that water strainer is not cloged or restricted. Hotpoints CODES change from year to year, You can contact a Hotpoint Dealer in your area ... Give him the Make, Model, and any Series numbers to him. MOST will tell you what the CODES ARE FOR THAT MODEL OR EVEN E-MAIL ALL OF THEM TO YOU. Good Luck ... Be Safe Joe Rex
Posted on Oct 09, 2007
SOURCE: Hotpoint Aquarius+ FDW70 Error Codes
Posted on May 24, 2008
  • 1462 Answers
SOURCE: hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
Posted on Jun 25, 2008
SOURCE: Hotpoint Aquarius DWF50 Dishwasher, cycle
hotpoint dwf50 will not start, the fast wash and prewash buttons are flashing together.
Posted on Sep 25, 2008
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
Dishwasher not doing anything
hi does anyone know what error A06 for the Hotpoint Aquarius FDW70 means and if it can easily be fixed
Jun 13, 2013 | Dishwashers
A06 fault code hotpoint FDW70
hi does anyone know what error A06 means and is it fixable
Aug 31, 2012 | Hotpoint Dishwashers
Help my Hotpoint FDW70 iS FLASHING a99...............Many thanks Sarah.
A99 is a communication error. Try unplugging your dishwasher for 10 minutes and then try it again. If you still get an A 99 code that suggests a problem in the control board in the dishwasher. In this instance I recommend an engineer as it can be extremely difficult to fault find this error.
Hope this helps.
Mar 09, 2011 | Hotpoint 24 in. FDW60 Free-standing...
My Aquarius FDW70 keeps coming up with code A10
Dear sir,
If your dish washer is type EV02 Module,
Error A10: means Faulty fill valve.
Check valve and associated wiring.
If your Dishwasher is
Standard Module + FDW70 + FDW75,
E10 means Heater fault.
Check heater and associated wiring.
i think it helps for solve your problem.
if you have any doubt regarding this issue leave a feedback we will glad to assit you.
Have a nice day
good luck
Sep 12, 2009 | Dishwashers
How do i find the float switch for a Hotpoing Aquarius FDW70
Open the DW. Look in the front right or left corner of the tub.
You will see a plastic dome.
The float switch is directly underneath the dome.
Remove the toe kick plate and located the float switch from the bottom.
Sometimes they get stuck.
Jiggle it then try the wash cycle.
If that does not work, replace the float switch.
Feb 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My aquarius hot point fdw70 comes up with error a10
Check out for all hotpoint error codes and what they mean
Oct 07, 2008 | Dishwashers
Hotpoint FDW80( A10 Appears ondisplay half way through cycle)
here are the fault codes for your machine...
Fault codes for LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water
  • Hope this helps?
    Jan 06, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
    May 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
    Hotpoint Aquarius Dishwasher DWF31
    Jan 03, 2007 | Hotpoint 24 in. DWF32P Free-standing...
    Dishwashers Logo
    115 people viewed this question
    Top Dishwashers Experts
